Hinson Motorsports is Installing an A&A Superhcarger Kit on a C5 Z06 This Week
Hinson Motorsports rolled a 2003 Z06 into the shop this morning to install a laundry list of new goodies:
- A&A Supercharger Kit - V3 SI Trim
- Kooks 1 7/8 Stainless Headers
- Kooks 3"x 3"x 2.5" Off-Road X-Pipe
- McLeod RST Twin Disc Clutch
- McLeod Steel Billet Flywheel
- Remote Speed Bleeder
- GM Slave Cylinder & Pilot Bearing
- ATI Crank Pinning Kit
- New Harmonic Balancer
- ARP Bolts
- HINSON Spark Plug Wires
- HINSON Spark Plug Heat Boots
- HINSON Urethane Engine Mounts
- SLP 160* Thermostat
- Comp Cams LS Rocker Trunion Upgrade
- Lunati LS .660 Lift Dual Valve Springs
Stay posted for daily updates on how this project is coming along. Visit www.hinsonmotorsports.com to check out all the SPECIAL WEB PRICES we have on every one of these items we are installing on this car.
2003 Z06 Project Starts with Base Dyno Numbers 100% Stock Z06
2003 Z06 Stock / Base Line Dyno Numbers
100% Stock For Now
A Table and Floor Full of "The Good Stuff"
We are starting with a 100% stock Z06. The fuel system will remain stock with larger injectors. The kit does not require an upgrades to the fuel system to run 7lbs of boost.
Good guess. Keep them coming.
So as promised we have a daily update for you. For purchasing the items in this thread see the links posted in earlier thread or visit our site for a full line of products www.hinsonsupercars.com
Today we have added a few other goodies to the C5 Z06:
HINSON C7-R Timing Chain
Throughout the course of the day we have installed:
McLeod Clutch and Flywheel
Pilot Bearing
Pinned the Crank
Balancer
ARP Crank Bolt
Trunion Rocker Upgrade
Lunati .660 Lift Dual Springs
160*F SLP Thermostat
MISC Seals and Gaskets
Cleaned the engine and got it ready to put back in the car
McLeod RST Clutch and Billet Steel Flywheel
Lunati Dual .660 Lift Valve Springs
HINSON Urethane Performance Engine Mounts In Yellow
HINSON C7-R Seamless Timing Chain
Pinning the Crank
Comp Cams Rocker Trunion Upgrade (Left) Stock GM (Right)
Comp Cams Rocker Trunion Upgrade Installed
Stay tuned for more. Tomorrow we will be installing all of the brackets, intercooler, putting the engine back in the car, and repairing the infamous C5 wiring harness damage we are all so familiar with.
Pilot Bearing
Pinned the Crank
Balancer
ARP Crank Bolt
Pinning the Crank
You cheated. Yea facebook page beat me to it on here but figured everyone on here would enjoy the build as well. We are new to this forum so its the first chance we have had to expose a potentially new audience to what we do here. Thanks for following us on facebook as well as on here. Help us spread the word and let us know if we can ever help you out.
Jack
Ill PM you the cost on it. The car did receive a lot of extras while it was here.
Literally an oversite when posting it. It was copied over from another forum.
Installation of the torque tube and trans
Upgraded the trans mound to a HINSON TRANS MOUNT
Installation the engine back into the car
Wired and plumbed everything back in
Fixed some wiring issues we discovered
Installation of the A&A Intercooler
Installation of all the exhaust
A&A Intercooler
HINSON Transmission Mount
Back In One Piece - Look at All the New Stuff
Kooks 1 7/8 Headers Off-Road Mids & X-Pipe - Makin' Sure She's Gonna Talk to Ya
A&A Intercooler
chris@hinsonmotorsports.com
We were able to see a horsepower increase of 234.76hp and an increase in torque of 160.58 ft/lbs. With horsepower and torque increase like this you would probably expect to loose a lot of drivability. The guys at A&A were able to create a kit that allows the car to produce these kinds of number and be very mannerly until you jumped on the throttle. Once you hammer down on the gas the car starts making huge power and screams like a kid that just had a butt woopin' in Wal-Mart. Another contributing factor to the great street manners was the Mcleod RST clutch we installed in this car to take all the power. Even being a twin disc 800hp clutch it has a lighter than stock pedal feel and will take all this car can throw at it. Keeping this beast all strapped together was a set of HINSON Motorsports engine and transmission mounts. Our interlocking stainless steel design, combined with a special blend of poly urethane helps keep the engine and transmission strapped in tight to ensure better shifts and less vibration. All in all the A&A kit went on pretty smooth and is a pretty quick way to achieve some serious power increases, and still be capable of being a daily driven Corvette.
If you are interested in any of these parts or having us build a car for you, please visit www.hinsonmotorsports.com or give us a call 205-909-9402.
Front End All Together & Ready for Delivery
Engine Bay All Ready to Go
Before & After Dyno #'s
