LS2 F1A new build. Let the fun begin.
The Burkhart Bumper Support just arrived & we were able to get the
Procharger race FMIC installed.
Bumper support needed some modification to get the job done.
1, The support bars were blocking the inlet/outlet on the IC.
2, A portion of the mounting brackets also encroached into the IC
( as they both mount to the original stock bumper location).
Both pieces are quality items & I'm very satisfied with the result.
In a nutshell, in an effort to mount this IC with this bumper support:
The mount brackets on the BS had to be trimmed ( see pics). The brackets on the IC needed an additional fabricated sheet ( bracket extention) to extend the mount a little lower. Effectively lowering the IC about 3/4". The remaining BS mount holes needed to be drilled/relocated to accommodate the adjustment to allow the support bars to clear the inlet/outlet.
In addition, the lower 2 dowel like mounts on the BS are not needed and would never fit with this IC ... so they were removed as well.
I hope the pics show below.
Also noticed Burkhart changed the support some... Yours has 2 vertical bars in the front and mine from last year only has 1 in the middle.
Looking good, glad to see you got the procharger cooler to fit the way you like. Any problems with the bumper fitting with the inlet and outlet of the cooler below the bumper support? The way the camaro fog lights sit in the bumper I mounted my cooler higher than you did.
Re; the bumper fitting. Haven't gotten their yet but looks like a non issue. Truth is every upgrade that we have applied needed some sort of modification .
It's all part of the experience, right !
If I'm not mistaken the reason for the verticals bars is that my support is designed for the TA while yours is specific to the Camaro. Burkhart makes a distinction between he two. Their web site shows only the Camaro version, but gives a choice between the two. I have to say that this is a well made & sturdy support. Chuck @ Burkhart was a pleasure to work with.
I hear ya on the "experience" comment lol. I had my car apart for 16 months last time around. Spent alot of extra time on the fit and finish rather than just getting it all crammed in the car.
Keep fighting the good fight, she's looking good.
It's gonna be a while before we get it on the rollers, I have to break in the new clutch first. We have to finish a few wiring details, get the top end in place, set up the catch cans, replace the coolant reservoir ( it's rubbing on the inlet pipe), heat shield the gas tank from the exhaust routing etc, etc, before we can even crank it over. However, I will get an exhaust review for you if your still interested.
FYI : I'm leaving the original Kooks cans in place for about a week after driving. Then I will replace with the B&B bullets. It will help me make the comparison.
It's funny, I'm friggin 50 years old and I'm feeling giddy @ Christmas time like when I was a kid. This **** is the best drug ever known to guys like us !
Now that you mention it Chuck did ask me too if this was a Camaro or T/A F-body.
The car has been in the shop so long that friends a family don't think I own it anymore. My neighbors are making comments like " I didn't want say anything but I'm glad I don't have to hear that animal warm up very morning ". I just grin & say " your gonna love 2015 ".
Its starting to look like a ProCharger build !
A few details left:
-last minute upgrade to fuel lines
-need to work out what will work off the stock ECU & not, finish off the wiring.
-catch cans
-wrap the cross pipe off the exhaust (under fuel tank)
the small detail list goes on forever. I'm still having problems getting the truck hat to fit. The inlet wants run right across the IC pipe. Not sure how others have done it ?? I may just fall back to the stock inlet hat.
I will say that the bumper slid right over the Burkhart Support (fits like a glove). I love how the BOV is visible through the vent.
Its dirty .... but its a work in progress.
A few details left:
-catch cans
#32
Our builds are very similiar I bought the f1c formula from wes last july Brought it home after driving it maybe a mile at his house never over 3000 rpm and took it apart to put in ac and improve the air inlet/filter setup. Things kind of snow balled and then deer season and the holidays ect I got back to work on it and maybe it will be irritating the neighbors soon mwc 9, alky control, kb bap, gz vacuum pump system, 14" brembos on the front with ccw 505s, more gauges, wide bands, be cool shifted forward at the bottom, aftermarket condensor and the aforementioned filter set up plus a lot of little things I am surely forgetting.
Same kind of thinking not a drag car but ought to lay it down pretty damn good
Interested in your true dual r&d Mine is loud but the blower is too i hope it is a little tamer the way i ran it Time will tell
#33
Thanks Brother !
She looks mean with the IC exposed through the fog holes & screen plate as well.
We may have found a solution to the truck hat situation. Take a look at the pic attached. On the right side ( in front of the ProCharger) you can see some sort of block attached to the frame rail. I think its the traction or cruise controller. Either way ....... its comin' out. This will allow for the truck intake to occupy that space as it should. Sometimes you can stare at things and not see the obvious.
This build is far beyond cruise or traction control anyway !!!!
#34
I will give a detailed review of the exhaust in its original format as well as the modified version to follow. I'm not expecting any noticeable quieting of the system however, I don't want to prejudge what I know little about.
No one is more interested than me to hear it run. At this point ... this beast has been separated from the street for so long I would welcome the sound of two squirrels running on wheel.
#35
LS1Tech Sponsor
Re: True Duals.
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
#37
LS1Tech Sponsor
Thanks. Bob
__________________
