Can you have too much wastegate?
I have a stock bottom 5.3 ls6 cam and springs on 243 heads stock truck intake. Borg Warner s475 t6 1.10 ar. Twin 44mm gates too much? Plan on running around 10-12 psi
Restricted User
You can only have too much if you get excessive (Twin 60s on a mild setup).
The less boost you want to run, the bigger your gate needs to be. With twin 44s you could probably run any amount of boost you want without getting any spikes. More gate = more control.
Restricted User
Running two large wastegates with a conventional vacuum system (no controller, running off of spring pressure) can make building boost take a long time. The gates will crack open as you build boost and bleed off a lot more gas than a smaller single gate.
There are obviously ways around this, but it is a downside.
1) Unless you are running a CO2 system, you will build boost slower due to "crack" pressure.
2) You have a significantly thinner wallet than the guy with a properly routed single china 44mm.
To add fuel to this fire-
Single 40mm- hold 8psi till redline on a built 6.0 just fine
https://ls1tech.com/forums/forced-in...lq4-t56-8.html
