Fender Exhuast Outlet
I just pulled measurements on how low I could go and referenced it to where my turbo was. I taped it off with painters tape and used a dremel.i had to adjust my cut a little on the exhaust and it put a very slight bend in it doing it this way but, I knew the exhaust was going to exit exactly where I wanted it and knew that I didn't put a 4" hole in bumper for nothing.
I just used a drill and drill bit don't even remember the size smaller than a 1/4 bigger than a 1/8. Just stuck the pipe up there about where I wanted it to be traced it out drilled a hole then followed the line.
