Opinions on 5.3 Nova build
Old 04-02-2015, 08:00 PM
g6t6o's Avatar
Default Opinions on 5.3 Nova build
I have a 5.3L LM7 with 40K miles, only mods are a TSP 224R cam which is .581/.581 on a 112lsa, PAC 1518 springs, TSP push rods, double roller & LS6 ported oil pump.
I'd like to throw a Denmah special on there and am wondering if I can use the motor as is or should I swap the cam out while the motor is out on a stand. Not looking to make crazy power, 600-650hp would do. Any other mods to the heads or motor I should do now?
This is going in a 65 Nova, haven't seen too many 1st gen Nova turbo builds, should be fun.
Old 04-02-2015, 08:55 PM
g6t6o's Avatar
Here is how I found the car a few years back. A few progress pics as I went along.
Old 04-02-2015, 09:04 PM
g6t6o's Avatar
Old 04-02-2015, 09:54 PM
Twinstang's Avatar
Looks good you move fast
Old 04-12-2015, 11:14 AM
army11b's Avatar
Default .
Very nice start, ill keep my eye on this... wish I could do body work...
Old 04-13-2015, 09:45 PM
Beanslsxnova's Avatar
Car looks great man! As far as the motor goes I would run it as is. Is that cam perfect for what you wanna achieve. No it's not. Will it work yes, and I think you will be surprised how well it will do.
Old 04-14-2015, 08:19 AM
Chicago TDP's Avatar
Put a 76 MM turbo on it and your will make your power goals.
Leave the motor as is other then tossing in a set of cheap head studs.
Hell, you would be fine even without the studs at 650 HP but you will want to turn it up...
Old 05-11-2015, 07:59 PM
garethmarshall's Avatar
Thats what happens lol. You always want to turn things up more. Keep up the resto. I'm a first gen nova lover and owner too
Old 05-12-2015, 07:25 AM
g6t6o's Avatar
A few more updated pics. Went with head studs, BTR .660 spring kit and made the engine look pretty
Old 05-12-2015, 07:26 AM
g6t6o's Avatar
Truck manifolds
Hooker manifolds
The truck actually fit a little bit better, will go with them.
Old 05-12-2015, 07:29 AM
g6t6o's Avatar
So I need some advice from the turbo guys, I really have gone this far without butchering anything on the car, I'd like to do the same to the front and run with no intercooler. I know it's not ideal but I also know it's feasible and I have E85 locally.
With my setup, a 4L80E with 3200 stall, anyone have a decent inexpensive turbo they recommend?
Old 05-13-2015, 07:50 AM
cr250r's Avatar
BorgwarnerS475 87mm turbine bullet proof and only 6-700$
Quick Reply: Opinions on 5.3 Nova build
