Question about wastegate vacuum..
Long story shirt. First turbo build just completed. Car had some issues with the computer so I had it re pinned to the 99-02. I never knew that their had to be a vacuum source running to the gate until last night. I've read most threads I could find on it today but still have a couple questions..
What does the vacuum line do? I thought the gate just simply released pressure when it hit X amount. Secondly, when i picked the car up last week, the turbo was spinning slower than I imagined it would and even when revved up to around 2500, I never heard the slightest sound coming from it. Would this be the cause? Turbo is a GT45, Emusa BOV and gate.
The wastegate has to have a reference or it wont know what pressure to keep. And i can rev my car to 5000 and it wont spool at all. Thats becuase you are not producing a load to produce heat to spool the turbo. some one correct me if im wrong about the wastegate and other stuff cause im defiantly still learning also.
Your car will use positive pressure, ie. boost to control the wastegate.
http://www.turbosmartusa.com/technic...astegate-work/
And just exactly how are you determining how fast is is spinning, and what noises exactly are you expecting it to make ?
There doesnt. Only some modern diesels use vacuum to control the wastegate.
It's still a constant learning process and sometimes even after long reads, your questions still aren't answered. I'll read the link you posted when I get time. Thanks for the replies.
Ideally, your waste gate should only ever see positive pressure (boost). You can drill and tap your compressor housing or do the same thing with the intake tube pre-throttle body (most likely would have to have a bung welded on as the tubes are thin). Both of those areas see boost and not vacuum.
I emailed Turbosmart and they told me if I cannot use the compressor housing, to use the intake tube pre-throttle body but it should be pressure only.
There are also silicone couplers that have ports in them and I have also seen an "add a port" but I don't remember who made it.
The wastegate has to have a reference or it wont know what pressure to keep. And i can rev my car to 5000 and it wont spool at all. Thats becuase you are not producing a load to produce exhaust volume to spool the turbo. some one correct me if im wrong about the wastegate and other stuff cause im defiantly still learning also.
