what tires do you guys use/suggest?
Old 04-19-2015, 07:37 PM
awd-rwd racer's Avatar
Default what tires do you guys use/suggest?
currently have 17/45/275 nitto nt05's on my rx7. car makes 626hp/667tqe. it still spins bad and goes sideways from a 70 roll.
thanks!
Old 04-19-2015, 09:03 PM
Camaro9969's Avatar
Mickeys I've always had good luck with. Your issue is more suspension related I'm guessing though
Old 04-19-2015, 09:48 PM
GoodSpeed150's Avatar
I use MT street radial. Use to spin at 70mph as well. Now it just dead hooks.
Old 04-19-2015, 09:50 PM
Red89GTA's Avatar
I'm by no means an expert, but a friend of mine has a very similar car to yours (even the same color!) but ls3/ no turbo. His car also lights them up really easy, especially if you're not pointing straight. I think a lot of it is the light weight of the car as well as the suspension not effectively 'planting' the tires. Are there any rx7 boards that have a good base of knowledge with v8 swaps?
On topic, any drag radial should help a ton (you have the NT05 or NT05R?) over a normal street tire. You just lose any longevity with them though.
Old 04-20-2015, 06:13 AM
MonmouthCtyLS7's Avatar
Mickeys here as well.
Old 04-20-2015, 08:51 AM
willizm's Avatar
Mickeys as well. Used the street et's when I had 17's and now run pro radials on my 15's.
edit: I just noticed you have a 6speed. Keep in mind that most of us run automatics so pairing it with a drag radial is going to net us better results than a guy with a 6speed.
Old 05-11-2015, 07:47 PM
garethmarshall's Avatar
I use et streets lol. But sounds like you need a suspension doctor. Find your instant center
Old 05-12-2015, 12:51 PM
Detoxx03's Avatar
One of my friends has a turbo rx7 and it had the same issues. The cars are so damn light that it will be hard to matter what. Drag radials and suspension will help.
Old 05-12-2015, 01:22 PM
gnx7's Avatar
NT-05's are not sticky.
I ran a 275/40/17 NT-05R drag radial and it put the power down 1000rwhp in a similar RX-7 setup (3.31 gears out back)... but at the strip it was inconsistent and out of about 8 passes only ran a high 9 once (9.87). I switched to 275/50/15 M/T ET Street drag radial and every pass was in the 9's. It also did some low 9's.
Any tire that is cold needs some heat in it. High HP cars on the street don't do well with cold pavement either. You should also look at a boost controller if you aren't ramping it in.... that is another issue.
Old 05-12-2015, 03:52 PM
SPRAYED 01's Avatar
I always recomend M&H racemaster drag radials. I run a 275-50-17, 1.4 60s on a 3950lbs car.
Old 05-13-2015, 02:27 PM
stevieturbo's Avatar
Any airfield or street type use ? how do they fair there ?
Do they work well without a burnout ?
Old 05-13-2015, 04:18 PM
SPRAYED 01's Avatar
I use them on the street/highway all the time and they hook great. I dont do a burn out on the street. At the strip I do a very short burn out and thats all they need.
Have not been on an airfield. I have had pretty much all the major drag radials in the same size and these definitely work the best. They wear great too, I cant believe I have about 1000 miles and 10 passes on them already. They still have plenty of life left.
Quick Reply: what tires do you guys use/suggest?
