could this reference port & line be too small causing hesitation ???
Old 04-27-2015, 09:36 AM
jaywill's Avatar
Default could this reference port & line be too small causing hesitation ???
Old 04-27-2015, 05:33 PM
jaywill's Avatar
C'mon how can u have 80 something looks !!! And no response ! This forum is falling off !!!!!!!
Old 04-27-2015, 06:36 PM
jordoza777's Avatar
Refrence port for what. Bov, Watergate or fuel pressure regulator etc.
Old 04-27-2015, 06:37 PM
jordoza777's Avatar
Describe hesitation maybe. What's hesitating.
Old 04-27-2015, 07:39 PM
jaywill's Avatar
The port is on carb hat...is the opening to small...The hesitation is when is going into boost some time It pull like a freight train some time it hesitates?? I was wondering if the small opening in the port could be causing it to not to get enough psi & fuel from the regulator causing the hesitation ?
BTW: see you from Las Cruces New Mexico ...I have friends that stay there .
Old 04-27-2015, 09:16 PM
jordoza777's Avatar
The tube looks large enough for a fuel regulator. If it was a waste gate or bov it might cause a hesitation in there operation because of how large a diaphragm they have but a fuel regulator is usually a much smaller diaphragm So it will work fine.what are you using for ignition? Could be a carb thing. does it run better after you have got in to it a few times.
Old 04-27-2015, 09:51 PM
jordoza777's Avatar
Cool about your friends. Small world.
Old 04-27-2015, 09:59 PM
chiaj144's Avatar
What does your wide and say when it stumbles? Reference line should be fine. Car wouldn't stumble if it was too small until it sucked the float bowls dry. What does your timing do when boost comes on?
Old 04-28-2015, 01:43 PM
jaywill's Avatar
the same size tube is on my wastegate and bov....i will have to look @ wide band next time i try it..
Quick Reply: could this reference port & line be too small causing hesitation ???
