Realistic HP on stock ls1 cam, heads on turbo
Old 05-31-2015, 06:28 AM
kk90's Avatar
Default Realistic HP on stock ls1 cam, heads on turbo
I am looking for realistic goals for my 2000 ls1 I have a 67 mm turbo mounted with arp head studs and skat piston and rods. I am wondering how far my stock cam and heads will actually take me.
any information would help thanks
Old 05-31-2015, 01:55 PM
IronBlocked's Avatar
Do you have long term reliability on your mind?
Depends on whihc 67, but probably 6, 700.
Old 05-31-2015, 03:17 PM
kk90's Avatar
I do, I am looking to swap out the stock cam and heads. but I would like to be a comfortable 600 at the track and 500 on the street.
Old 05-31-2015, 04:22 PM
Restricted User
JoeNova's Avatar
Which 67mm turbo is it?
67mm is normally a pretty small turbo, especially for a pistons/rods LS1, unless its something like a Borg Warner which can have a very large turbine for that size compressor.
500 to the wheels with a stock cam is pretty reasonable for a quality 67mm turbo.
Old 05-31-2015, 07:10 PM
kk90's Avatar
I believe it is a precision 67mm with a 60 ar compressor housing. its not very big.
Old 05-31-2015, 07:16 PM
kk90's Avatar
once I get all the bugs worked out in this set up I do plan on upgrading the cam and heads as well as the turbo an the fuel pump. I have rather high goals for this car. an I want to do it on the 347 block. an its not really a budget build its a toy so I treat it like one.
Old 05-31-2015, 07:19 PM
Ryans99ls1's Avatar
click on the build thread in my sig. 67mm is pretty damn small regardless of your hp goal
Old 05-31-2015, 07:42 PM
Restricted User
JoeNova's Avatar
You can get very very very far without upgrading heads. Cam is a preference, but with the right turbo the stock cam will make considerable power. Once you go with a larger cam, you open up the opportunity for increased backpressure and reversion, as well as increasing the CFM demand of the engine and putting the compressor in a different efficiency zone.
I would stay stock heads and cam for now, and upgrade the turbo. A cam/head upgrade with that turbo is going to be pointless.
Do you have any idea what the A/R is on the turbine or what size the wheel is?
Old 05-31-2015, 09:15 PM
kk90's Avatar
this is good info. the turbine housing is a .68 A/R it is fairly small. but I am working on spooling issues. I do not have any boost leaks. But my tune is extremely rich an i have yet to put heat tape on my hot side. ( for the record this is a rear mount). but what size do you recommend moving up to? 70mm?
Old 05-31-2015, 09:29 PM
Restricted User
JoeNova's Avatar
You can get away with less turbine on a rear mount setup, but .68 A/R on the turbine is still tiny. That turbo will probably start to choke around 500-600 whp unless it has a huge turbine wheel.
I would actually recommend the On3 76mm for this. Small turbine wheel, and you can get away without the need for the standard .96 A/R they offer and get something slightly smaller. Its also a small turbo so it would work well with a rear mount.
Otherwise I'd say go with a TC76. Thats probably a good size turbo to start considering a better cam with.
Old 05-31-2015, 09:42 PM
kk90's Avatar
I have 8:5:1 cr so the car is a puss down low till it hits boost. Thats y I have the smaller turbine housing. But your right once I hit boost it feels like the car is not pulling through the turbo. if feels like a na car pulling the same through out. But i am only running on wg which is 6 lbs. how many pounds do you think I am safe to run with the proper tune? With what your saying makes sense. I feel like it has so so much more there.
Old 05-31-2015, 09:46 PM
kk90's Avatar
also is that turbo on a T3 or T4 flange. I am running a T3 do you think with the larger turbo I should go to a T4. I am still kind of New to all of this. I am learning as fast and as much as I can.
Old 05-31-2015, 09:58 PM
Restricted User
JoeNova's Avatar
I think the current record for stock bottom end LS1 is around 800 whp. I'd say with forged pistons and rods and a good tune, you're set for pretty much whatever the block itself can take.
Yes, I'd consider upgrading to a T4 in the future, but for now you could probably get 12 lbs or so out of that turbo before it starts to run out of steam.
Old 05-31-2015, 10:14 PM
kk90's Avatar
I have been doing some quick reading on here. an reading up on the tc76 which I like what I am seeing number wise. you pretty much convinced me to switch. I have been wanting to for a while but i have so many other things that are messing me up. I put a Th400 in the car an put a TCI 10' converter with 3500 stall. an when I take it out on the street it literally does not see 1lb of boost till 3800rpm. I am looking to get a lower stall. about a 2400-2800 for more street driving. but leaving of the trans brake it will blow the tires clean off. I feel like its not even running right to even get a good grasp on power. the motor is finei nlbelieve its in the converter. what do you think?
Old 05-31-2015, 10:46 PM
Restricted User
JoeNova's Avatar
3500 is a pretty loose converter for a street turbo setup. Turbos like load. Load creates heat and helps with spool. Even a lot of the 700+ hp guys are running a lot less than 3500 stall.
Your transbrake helps create tons of load as well.
Old 05-31-2015, 10:59 PM
kk90's Avatar
what stall do you recommend?
Old 06-01-2015, 12:03 AM
kevin87turbot's Avatar
You definitely need to tighten up that converter several hundred rpm. An 086 stator and a "0" impeller is a good start. You might just call up TCI and get them to do it. Ondra is the man to talk to.
Old 06-01-2015, 05:55 AM
kk90's Avatar
thanks, this is good stuff. it is def loose to the point where it feels like its in the clutch thy whole time.
Old 06-01-2015, 11:45 AM
Restricted User
JoeNova's Avatar
Id tighten it up to less than 3000 stall.
Most 1000 hp turbo street cars ive dealt with run 3400 or so stall. With a smaller turbo, and a rear mount to boot, youre looking at 2600-2800 for a decent stall speed.
Quick Reply: Realistic HP on stock ls1 cam, heads on turbo
