2008 ly6 or 2004 6.0 for boost?
Old 06-22-2015, 03:37 PM
Superlate62's Avatar
Default 2008 ly6 or 2004 6.0 for boost?
Just bought a 2008 ly6 for 500 bucks. Plan is twin s366, csu blow through 750 carb. Should I stick with this engine, or trade it for the 2004 6.0?
Old 06-22-2015, 04:00 PM
And I can trade for a 2004 tonight, so advice/input ASAP would be great
Old 06-22-2015, 04:21 PM
rpm-inc's Avatar
Keep the ly6
Old 06-22-2015, 05:14 PM
Alright pros and cons? 58x vs 24x? Has 823 heads on it, can always swap heads.
Old 06-22-2015, 06:44 PM
rpm-inc's Avatar
I am by no means an expert... but the crank reluctor is irrelevant if you are doing a carb. The ly6 has stronger rods than a gen 3 lq4. 317 and 823 heads are both great for boost. No need to change the heads, imo.
I sold my 03 lq4 to get an 09 ly6, mainly for the rods.
Old 06-22-2015, 10:34 PM
RubbercitySS's Avatar
I thought the 04 6.0 had the better rods.
Old 06-22-2015, 10:37 PM
IronBlocked's Avatar
Nope, gen 4 engines come with the beefier rods
Old 06-22-2015, 10:43 PM
tiznodd's Avatar
04 and up LQ4's got floating rods like the Gen 4 stuff.
Old 06-22-2015, 10:57 PM
That's what I thought but I wasn't sure
Old 06-22-2015, 11:06 PM
9 Second Truck Club
stock48's Avatar
That's a hard one. Most 04's had the good rods but a few had the early rod. If the o4 has the floating rods and is in good shape IMO they are a little bit better engine.
Old 06-23-2015, 12:30 AM
VintageCamaroChris's Avatar
i believe the earlier one has 10mm bolts on the valley cover, and if they are 13mm they have the updated rods if you cant pull the pan. I cant imagine gm putting the gen 4 rods in every 13mm block, it would be typical of them to have a certain number leave the factory mismatched, but i could be wrong.
Old 06-23-2015, 06:29 AM
69-chvl's Avatar
Interestingly my ~04 LQ9 had the floating rods, 24x and all even sized head studs and 10mm valley bolts.
I think all LQ9's had the floaters.
Quick Reply: 2008 ly6 or 2004 6.0 for boost?
