Whats the highest dyno number you have seen from a S475?
Whats the highest dyno number you have seen from a S475? No I'm not looking to break any records and know dyno numbers are just a tool. In conversation with folks I'm seeing that most S475's are tapped between 700-750whp range through autos. I want to say the most I have seen is 800whp through a 6speed. Has anyone seen more?
What S475? The larger 1.32 T6 96mm wheel on a 4.8 would have the most potential. Unfortunately we don’t see many people using the 4.8’s. On my 5.3 I’d pick a solid 1+mph up to 23lbs. And about a half mph at 24-26lbs with the small 1.10 T4 s475 (small 83mm wheel version) Looking at stock48’s weight and trap he was over 850whp with his 6.0/auto setups in the truck and nova. Both had the small box stock S475’s on them at one point.
Rick if you don't mind me asking what motor?[/QUOTE]
I have an 03 6.0 block that we put gen 4 pistons and rods in. Mine is a box stock t6 1.32 ar.
I've only made three passes on the car so far. We've been a best of 9.71@131 shutting off a bit early. No license or certified cage. This was on 15psi max leaving off the footbrake with zero boost. Best 60' was a 1.561. This is in an 88 Cutlass weighing around 3500.
Any of them..
Was his cast wheel?
I've only made three passes on the car so far. We've been a best of 9.71@131 shutting off a bit early. No license or certified cage. This was on 15psi max leaving off the footbrake with zero boost. Best 60' was a 1.561. This is in an 88 Cutlass weighing around 3500. What was the 1/8 mile?
Have you seen what a BILLET wheel /race cover 475 would do?
I went 6.21 @ 114.50 in the 1/8. This was at 3400' corrected altitude and into a decent headwind. Unfortunately our racing is done for the year around here. So we'll see next spring. Doing some chassis updates and get the trans brake hooked up. I think it has at least 5.8's in it on a decent day and decent launch.
Yes Stock48 originally ran the small wheel cast S475. 3400lb nova went 5.7 @ 127. And 8.9 @ 157.5 in the 1/4 first time out.
That comes out to 1030ish crank hp going by weight/trap. That's the most power I've seen anyone squeak out of one. Slips and all are in link below.
http://www.yellowbullet.com/forum/sh...d.php?t=581173
