Head Lifting or torched HG
Old 10-26-2015, 07:32 AM
Man-Crush Warning
Shownomercy's Avatar
Default Head Lifting or torched HG
Car seems to drink water and I can't seem to narrow it down. Had to add ~.5 gal yesterday after a few WOT hits the night before. (Edit: This is an LT1, gen 2, just to be clear)
-Car never overheats
-Plugs look really good, tune is good
-Oil is dark as sin, but no sludge
-The usual steam at cold start up but nothing at hot idle
The only odd symptom is a semi frequent water discoloration on the side of car that overflow is on. Dream would be that overflow (1qt) is too small and it fills then overfills before motor can draw back in. But reality is its prob torched a HG.
Thoughts?
Old 10-26-2015, 05:01 PM
stevieturbo's Avatar
Monitor pressure in the cooling system, that will give a better picture of what's going on in there under load.
Old 10-27-2015, 07:48 AM
Man-Crush Warning
I have no real way of doing that, running an 0411 PCM so nothing fancy to add another sensor to.
Old 10-27-2015, 07:50 AM
A plain and simple pressure gauge is better than nothing
Old 10-27-2015, 07:57 AM
Man-Crush Warning
I can see what I can rig up with a port on the head.
For the time being I ran a line from the top of the overflow tank to the rear with another tank in the back just in case it is pushing water.
Would doing another torque on the studs be worth the effort of yanking manifolds? Or are HG trash regardless if head lifted?
Old 10-27-2015, 12:06 PM
3 window's Avatar
I ALWAYS retorque after getting it hot for the first time. Pain in the ...., but it's worth it to me. Give it a shot. Won't hurt and might fix your problem. Plus, they sell the tester to see of you're getting exhaust gas in the coolant system. Never bought one, but I have used them at a shop in the past. They work well.
Old 10-27-2015, 12:37 PM
Man-Crush Warning
Gonna pressure check the system tonight, if its a leak, maybe try re torquing but I think once its leaked, the gaskets are gone no?
Old 10-27-2015, 12:41 PM
Forcefed86's Avatar
The push to reset tire gauges make for a nice and easy way to record max pressures for under $5. good idea to have one on the cooling system. My also check the VC vents for signs of coolant. I had very small amounts of coolant in my catch can and vents.
Old 10-27-2015, 12:42 PM
MLS gaskets are pretty resilient, but when they're gone they're gone. No amount of re-torquing will change that.
But if it's handy enough to do, it can do no harm.
Old 10-27-2015, 12:50 PM
Man-Crush Warning
I will look into that, I didn't notice much goop when I drained my catch can last oil change, but just dumped it and walked away.
Removing the headers and re-torquing is only less painful than pull heads by the cost of buying gaskets Either way, the process sux0rs.
Old 10-27-2015, 08:15 PM
Man-Crush Warning
Tossed 18lb in radiator, left it for about 40min, lost ~4psi
Guess I am pulling heads.
Old 10-28-2015, 03:52 AM
SSZ
SSZ's Avatar
I wouldn't yet.
I ran into similar issue with my quad. Same symptoms.
I bought that kit for checking for exhaust gases in the cooling system.
That's what I had. I was gonna pull the head and do the gasket then said screw it and did a re torque. Problem solved. It's been close to ten years I bet. I know it's not the same engine but same symptoms.
Old 10-28-2015, 07:27 AM
sbcgenII's Avatar
http://m.napaonline.com/parts/PartsD...006_0361073538
Old 10-28-2015, 09:35 AM
Man-Crush Warning
Coupled with a few clunks when cranking, I am finally accepting I need to do HG.
Standard felpro 1074's or MLS like I was running?
Old 10-28-2015, 09:38 AM
Forcefed86's Avatar
MLS is kinda vague. The LS9's plain work, I wouldn't run anything else on a mild build.
Old 10-28-2015, 09:41 AM
Man-Crush Warning
SBC gen 2, so its a TFS MLS .040 compressed gasket. No alphabet soup engine stuff here.
Old 10-28-2015, 10:21 AM
3 window's Avatar
What do you mean clunks when cranking? Did the engine hydro -lock at all? If it did pull it apart and have the rods checked. I lost 2 engines in the past due to bent rods from hydro locking. Stupid on my part. One was from a small leak around the head gasket oring and the other was from an actual part of the head casting fell out. If you bent a rod, the engine will eventually spin the rod bearing and weld itself to the crank. Not good.
Old 10-28-2015, 10:28 AM
Man-Crush Warning
Yea I will be checking to see if I shortened any rods when heads come off.
Old 10-28-2015, 10:29 AM
Forcefed86's Avatar
Doh! I assume everything on this sight is an LS I suppose. I never had good luck with the graphite gaskets. They are a great weak link to have. If I ran into any detonation they’d blow quick. Unfortunately they would also tend to leak after a year or 2 on their own when running "big boost". If your confident in your tuning I’d go with the MLS.
Old 10-28-2015, 10:34 AM
Man-Crush Warning
I think the tune is fairly conservative and I am not really asking much from the motor. Will def be checking heads for straightness and rods for shortness.
Hopefully this is a cheap fix.
Quick Reply: Head Lifting or torched HG
