Where to find a small, thick radiator for 750whp
Old 01-23-2016, 07:49 PM
dburt86's Avatar
Default Where to find a small, thick radiator for 750whp
So im getting close to the point in my project where i need to find a radiator. The problem is there isnt much space, at all. I have about 22.5 inches wide and 16-17 inches in height, but i have an almost unlimited amount of depth.
Ive been told to look into rad's for SK modified and those types of cars because they need too be pretty small and thick and still keep high HP engines cool, but im having a hard time finding something.
If anyone has any tips or thoughts, or places to look to find a reasonably priced radiator (id like to stay under 300$), im all ears.
Heres a pic to see what im dealing with. Basically in between the headlights, under the rad support.
I can go taller if i truly need to, but if i did go any taller then 16-17 inches, it would end up being the lowest part of the car (which isnt that low at all)
Thanks!!
Old 01-23-2016, 07:58 PM
Restricted User
JoeNova's Avatar
Denmah had a lot of luck with small half sized ebay radiators that were for Fox mustangs.
Old 01-23-2016, 11:40 PM
unnatrl's Avatar
I used a circle track radiator (dual pass) with very similar dimensions. Make sure you use a really good fan. A Taurus 2 speed fan worked decent. I went through hell trying to keep my turbo LS E36 swap cool. A 26x19 radiator was the eventual solution.
Old 01-24-2016, 06:50 AM
stevieturbo's Avatar
Looks a decent size ? Just fit the biggest rad you can within that space. If there's nothing off the shelf have one made.
Old 01-24-2016, 07:02 AM
dburt86's Avatar
Do you have any pics of the bay? I think ive seen some youtube vids of yours. Is it still together?
Id Dual Pass the thickest they make? Is going any thicker going to help?
Old 01-24-2016, 08:59 AM
M.BOZZ's Avatar
I have a Griffin circle track radiator; its a two row 3 inch thick, 15.5 tall and 22 long. Looks like a nice piece . part # gri-1-55181-x
Old 01-24-2016, 04:33 PM
dburt86's Avatar
Thats almost perfect!! thanks
How does it work for you? Turbo car? what fan?
Old 01-24-2016, 06:08 PM
Forcefed86's Avatar
Nice fan/shroud is really important. I'm using a 3-row 14x14x3.5 triple pass core. Without the bad boy taurus fan it would over heat.
Old 01-24-2016, 06:15 PM
dburt86's Avatar
wow thats small. Do you ever street drive it?
Those taurus fans rip. I think i may have one kickin around.
Old 01-24-2016, 06:20 PM
unnatrl's Avatar
This is a pic of the 26x19 with a MKVIII fan. I believe it is ~3" thick. The manufacturer is C&R racing radiators. As a bonus, the top rail is finished. It looks "pretty" :-)
Old 01-24-2016, 06:26 PM
Forcefed86's Avatar
I always street drive mine. Don't own a trailer!I plug the bypass in the water pump and run without a thermostat. 80* night with the fan on high I can get the car down in the 160's in the staging lanes. 100* day I can cruise about 190*. And I have the intercooler blocking it almost 100%.
Some pics when I as test fitting it. I glassed the top/bottom and RTV sealed it to the radiator.
Old 01-24-2016, 06:35 PM
dburt86's Avatar
well that makes me feel alot better.
Im thinking that griffin rad posted above, shroud and tuarus fan, i should be good.
Maybe grab a 160 T stat or drill holes in mine or something
Old 01-24-2016, 09:29 PM
CameronVic's Avatar
Didn't read previous posts, but check out eBay for the 1965 mustang radiator. I have it in my car, keeps the engine 185 and below idling in traffic in the summer. 160* thermostat, and a bomb *** fan.
Quick Reply: Where to find a small, thick radiator for 750whp
