Help with Turbo 5.3L Build
Old 02-15-2016, 09:27 PM
Blake_s14's Avatar
Default Help with Turbo 5.3L Build
So i'm planning on building a street-able 800hp turbo 5.3L. As of now i'm looking at getting a stock LM7, FAST 92mm intake and throttle body with most likely a Garrett 45R and LJMS Turbo Cam (stage2/3). Still not sure what fuel system to run (injectors, fuel rails, etc) or if 317 heads are needed.
Old 02-15-2016, 09:39 PM
1999Firehawkls7's Avatar
Im doing the same thing, 600-700whp
I went w 317s on my 5.3 cause that's what I had laying around but it drops the CR down to 8.5:1 which is very low, if I was doing Big Single id def switch over to a set of 241s or 241s and ditch the 317s
Im not to worried tho cause im going w 2 small turbos that should spool quick regardless
Old 02-15-2016, 09:42 PM
Blake_s14's Avatar
Ok cool. What about using the stock heads? Maybe port and polish them?
Old 02-16-2016, 06:47 AM
Restricted User
JoeNova's Avatar
... Just run what you have and don't overcomplicate it. You can hit 800 HP on a stock truck intake and a baby cam.
Old 02-16-2016, 06:51 AM
Blake_s14's Avatar
Ok. I want a pretty decent cam though. I want it to lope more than my 4 cylinder. Lol
Old 02-16-2016, 09:34 AM
2muchboostNY's Avatar
I wouldnt spend the money on the FAST Intake for a boosted application for your HP level. A stock LS6 intake can be had for cheaper and will do the job well enough unless you are OCD about getting every last drop of HP out of your setup.
I have seen a few guys in your power range using the
Old 02-16-2016, 09:36 AM
Blake_s14's Avatar
Ok. I'll probably go with the ls6 intake or maybe even the stock one. What injectors and fuel system should I use for my goal?
Old 02-16-2016, 10:18 AM
91 240's Avatar
on my 6.0, untouched 317 heads, stock ls6 intake, 232/240 cam, 8psi on 76mm turbo, and 60lb injectors at 70% duty cycle, single bosch 044 pump and aftermarket rails, I made 608whp. i'd say 80's would get you to 800 safely
Old 02-16-2016, 10:23 AM
Blake_s14's Avatar
Ok cool. Thanks!
Old 02-16-2016, 10:37 AM
Restricted User
JoeNova's Avatar
Stock 5.3, 10:1 or so compression, small 218/218 cam that idles fairly well, stock heads, stock truck intake and throttle body, 80 lb injectors, 75mm turbo, heavy *** 4L80e, I made 700 wheel on pump gas.
Old 02-16-2016, 10:39 AM
Blake_s14's Avatar
Ok. I'll just stick with a stock 5.3 until it blows then. Lol
I just want to be able to make 800+ I'll drive it at like 500-600.
Old 02-16-2016, 11:32 AM
Restricted User
JoeNova's Avatar
05+ engines have stronger rods and floating wrist pins.
Old 02-16-2016, 11:54 AM
Odd half my thread post got lost.
^If you can find an 05+ 5.3 it will will have the stronger rod design and timing chain design. Some 04's got them but its hard finding the exact production date when they switched.
FIC makes some killer injectors for $700 which are 1000cc. These can take your E85 ssetup or pump gas setup to the power goals you want. Ebay fuel rails (
Old 02-16-2016, 12:06 PM
Restricted User
JoeNova's Avatar
80 lb dekas are half the price of FIC 1000s and are good for 1000 flywheel on gas...
Old 02-17-2016, 01:57 PM
At what PSI? I was offering a larger size just to accommodate any use of E85 and also lower base pressure. Not to say I havent seen 80 lbs. Dekas used at over 100% duty without many noted issues.
Old 02-18-2016, 08:46 PM
http://www.ebay.com/itm/like/281285330948?ul_noapp=true&chn=ps&lpid=82
Those are a good price!
Quick Reply: Help with Turbo 5.3L Build
