19-20psi boost....LS6 intake just fine...?
Simple answer, yes.
But if you haven't purchased either, don't waste your money.
Crazy power has been made on stock ls1 intakes by many. Just get the stock ls1 Intake if you don't have any and don't overthink it, seriously.
You'll need to spend money in more important areas with FI as youll soon find out !
Simple answer, yes.
Thats cool.
I have an LS6 intake still on my new 390ci...I got it in 2002 when I got my 427ci built.
Thanks.
I was going to upgrade my heads to something better....I still have my old ported LS1 heads from my 427ci back in 2002....LOL
I think I'm just gonna stick with the LS6 intake and get some LSA or LS9 heads.
Lsa/ls9 heads are rectangle ports
You would need a new intake to match that port.
Unless you're looking to go to an aftermarket casting id probably stick with the heads and intake you have now
Like you mentioned.....A few people told me to just stick with my old ported LS1 heads and LS6 intake and see what kind of power I make. Then upgrade them if I want to make a bit more power.
But the extra strength of the LS9s will help a bit if I try to go 19-20psi with 4 bolt heads.
We'll see soon enough.
Your already ahead of the gave with that Intake and those ported heads.
Just run em!
The goal or question isn't psi of boost, its how much power do you want to make?
I have ran upwards of 26-27psi through a stock 317 head and 22-23psi through a milled 823 square port head. Both on stock ls6 and ls3 intakes.
Please listen to the people who have made tons of power on bone stock stuff and save yourself alot of money !
Just run em!
Just run em!
I'd like to hit the magic number of 1,000 RWHP. Im hoping with 390ci at 10.8:1 cr, S484 84mm compressor/96mm turbine and race cover. E85 and through a 4L80E.......it will make 1,000 RWHP.
I would give the ls1 heads a try. I went similar times/mph on cathedral vs square port. 8sec setup. Actually best mph in the 1/8th was done when the car was SBE with stock 317 cathedral heads on it. But was about 6psi over the square port setup. If anything i would agree that the ls9s might be a good idea for sealing but still id give the ls1 heads a shot first.
I don't drag race....it will be a 100% roll racer.
