Borg Warner turbo size
Compressor Specs:
69.4mm compressor wheel inducer 82lbs/min
5'' Hose inlet
4.21'' V-Band Outlet Compressor Cover
Turbine Specs:
81.74mm turbine wheel exducer
1.58 A/R Twin Scroll T6 Turbine Housing
5.75'' Marmon Outlet
is this good for a 346 SBE LS1?
5'' Hose inlet
Turbine Specs:
I think it would get to the 650 range on higher boost. Do you have this already? Get a 171702 borg part number if your wanting to use a t6 turbine and its 75mm compressor side and give you room to grow.
Restricted User
That turbo looks like it was setup for someone who plans to make 600whp on boost and throw a 250 shot on top of it, especially if its a cast wheel.
What about:
S400SX4 Turbocharger•75mm / 2.94'' Compressor Inducer Dia.
•3.94'' Compressor Wheel O.D.
•88mm / 3.47'' Turbine Exducer Dia.
•96mm / 3.77'' Turbine Wheel O.D.
•1.32 Turbine A/R
•T6 Twin Flow Turbine Inlet
•Straight Compressor Outlet
•1.32 Turbine A/R
That is the standard S475 that everyone uses.
The 171702 borg part number is the one everyone is using and the specs listed above. They can be had for around 700 all day long. It will do anything you need for the most part. Its a little large but you said your making the hotside so no biggie.
