Sbe 5.3l rcsb 4wd; 10.91 @ 124.65
Guys joining the ranks of many with another 10sec SBE Silverado. Stock big rod 5.3L, milled heads for 10.4:1, Tick Stage 1 Turbo cam, Trick Performance Stage 3 turbo kit, Trick Stage 5 4" race intercooler, 18psi on an Trick 76/75 turbo, ARP studs, LS9 gaskets, ID1000, dual Walbro 450 on a Hobbs, E85, 4" exhaust through the tailpipe (not cutout), 3.42 gears, 265/60/18 Michelins, Cal-Tracs, QA1 double adjustables, 4L85e, Transgo, Circle D 3200, stock driveshaft, 4wd launch, truck weighs ~4900 with me in it and 3/4 tank of E85.
There are lots of other considerations with 4x4 tho... torsion bars, input shaft for 4L80e conversion, shortened and lengthened driveshafts for 4L80e, and you can only lower so much with a 4WD. There had been times when I wished I was 2WD! But it's definitely neat to 60ft on cheap radials as well as 2wd guys do on slicks. Earlier in the day it was doing 1.65 a couple times. I know I could get this thing into the 1.5x with fresh tires and more seat time/ shock adjustment/ Cal Trac adjustment. It's definitely fun to drive to the track, air the tires down a bit, stiffen the shocks, and run. Before I figured out the suspension, it was frustrating since it would only go 1.8x - 1.9x on the radials.
