6000rpm POP!!
6000rpm POP!!
seems my TT SEFI wont turn past 6K
symptoms remind me of the burnout pop you hear on turbo cars
A/F is solid 12:1 . FAST and MSD rev limiters disabled. timing 28 .
was running 93 octane ,switched to 100, no difference, just a tad fatter.
making 20# boost went down to 12# no difference
150# injectors and big aeromotive pump so fuel isnt a problem
45#FP boost referenced regulator
I dont see full spool until 4500-5000 so turbines arent choking
changes in boost didnt affect it so I doubt surge
105MM wilson TB, elbow and intake conversion.
brodix227cnc heads and intake
.630 mech roller .200 long valves plenty of spring.
keep in ming this getup was built and tuned by myself, with lots of
professional help with the component selection.
ANY ideas are greatly appreciated
thanks for the reply and compliment
I have the RPM rescaled to 8k
I think the default was 7K
the XFI is my only fuel control
power-adder controls disabled
I'm using the fast harness with IAC (its unhooked)
msd digital 6 dipswitches are set 8cyl, revlimit and start retard disabled
the green loop is intact
using the crank trigger for a crank position sensor
crank reference angles are all good
I have modified my non advance style MSD distributor by
cutting off 7 of the reluctor tabs and installed set screws to adjust the
reluctor 20degrees ahead of the rotor for a cam position sensor
I have been told that the FAST will run sequential without a cam sensor
so I unhooked my distributor once. seems like throttle response was the only difference I saw. I assume it guessed where #1 was?
I phase my rotor at my average timing and drill a hole in the cap to
check it with a timing light
Im sure its something DUMB that I have overlooked or maybe a tuning issue
Are both of the rev limiters off in the XFI? The low and high limit set to 8000 or so? The XFI has to have a cam sensor signal for sequential. If it looses the signal it will batch fire. The cam signal should lead your crank signal by 10 degrees or so. Which it sounds like it should be. The injection point is adjustable in the XFI by the way. What is your crank trigger air gap?
ahh
thanks for the info on the XFI
I have the high/low power adder on 8&9K with locked timing just in case
the only rev limiter I see is in the spark functions menu
I have also rescaled the timing rpm table to correspond to the fuel table
air gap on crank trigger is .020 or so
I have had the ignition apart and readjusted with the same results
the engine pulls strong
the thing just gets to 6k then "pop"
I held it there once and it surges between 5&6k
it just wont rev past 6K
the boost climbs a tad more on the datalog but the rpms drop
kinda making a backwards loop instead of the forward ones you normally see
keep picking guys I'm sure someone will figure it out
Plugs????
What do the plugs look like?
What kind?
What gap?
Closed loop? If so, what kind of O2 correction are you getting?
IS the FP keeping up?
I've had that problem with platinum plugs in my Turbo Buick. Got rid of them, went to AC's, and gapped them at .025". Engine was "sour owl ****" on the dyno with Ac's gapped at .032. Closed up a fresh set to .025, and picked up 70FWHP.
Just throwing out some ideas....
What kind?
What gap?
I think I may know where your problem lies.
Hook up your laptop, open Ccom WP XFI, go to View -->System Configuration-->Operational Parameters and look for "Fuel Cut On RPM" and "Fuel Cut Off RPM". The factory sets a low rev limit. Check it out!
I always set the crank trigger air gap to .060" FYI.
ooooops.....
if all else fails read the instructions
I ASSuMEd the fuel cut off RPM was a fuel pump control
since I am using a toggle switch this wouldnt have mattered
"the fuel cut-off will prevent the injectors from firing until the engine
drops below the value specified in fuel cut-on"
since the default setting was 5700 I am almost positive that this is the problem. this also explains the lean "pop"
I have set it at a conservative 8500 & 8600
dam its after 11:00 and I like my neighbors
guess I'll have to terrorize the morning yuppies to find out
Originally Posted by Rusted40
ooooops.....
drove it this morning
it got too sideways so I had to shortshift
but from what I can tell, this was the problem
I go to lunch at 11:30 so I'll repost about 12:00
WOW!!! Like somone else posted nice setup!!!!
i love new projuects but there always seems to be a little glitch the first few days of driving that will make you nuts trying to figure it out.... but in the end all teh time and effort pays off and in your case it was just a shortshift away LOL
post a few more pix of your setup and what car its in!!
Blake
Blake
WOW!!
what a rocket!!
just starting to get happy at 6K
andereck, your checks in the mail
LTLHOMER, based on the fact yours goes fat on stumble, I suspect
you have a spark issue. since I have no experience with BS3 I would hate to speculate, but it is probably some simple setting in your EFI config, or maybe
ignition box. a friend of mine had a similar issue with a digital6 MSD box.
turned out he had the cylinder select on odd-fire 6cyl. ran fine
till about 6500, but with 2 extra firing impulses per rev, the rev limit came sooner. simple mis interperetation(sp?) of the instructions...like my problem
heres a link to my homepagehttp://home.nc.rr.com/streetrodz/home/
its free and small
what a rocket!!
its free and small
