Hit the track last night with the 3.4 pulley and 2 more PSI
Old 06-17-2006, 09:18 AM
kp
kp's Avatar
Default Hit the track last night with the 3.4 pulley and 2 more PSI
And ran slower then the last time out with 13psi lol.
It was about 20 degrees warmer (same track) and the IATs were a good 20-25 degrees hotter at the end of the 1/8. But in the end the car with 15psi on a 80 degree evening (~3000 DA) as opposed to 13psi on a 60 degree evening (1900' DA) ran about 1/2mph slower. Sixty foots were not so great, 1.40 to 1.44, compared to 1.31 to 1.34 the last time and thats why the ET wasnt there.
So obviously the IAT is a factor, I actually had to lean the car out with the higher boost to get the same a/f as the last time out with less boost so if its not using the fuel its not making the power. I may be also just plain hitting the limits of my cam/exhaust also. Not to mention the blower spinning faster takes more power and makes more heat. With decent 60's I would have been in the 6.0x range again so I guess that isnt bad for the DA but I expected a little better with more boost. Maybe its time for a cam swap to see what happens.
Been kinda quiet lately, installed a cage in the car and what a PITA that was. Kind of wish I didnt do it but I was getting sick of getting thrown out of the local tracks with a 6pt..
few passes, car never really hooked well. Ran 6.42, 6.25, 6.153, 6.151, 6.150, 6.150, 6.141 so at least its a good bracket racer
http://video.ls1tech.com/video/69e24...02352e4d77.htm
Old 06-17-2006, 02:40 PM
frcefed98's Avatar
A tad more weight from the cage, hotter temps, hotter, IAT's 3000ft DA...of course you ran slower
Keep at it, I have faith in the 3.4
Old 06-17-2006, 02:43 PM
Got Me SOM's Avatar
good job man.
Old 06-17-2006, 02:54 PM
Coal Mining Director
onfire's Avatar
25 degree delta at the 1/8 is a lot...Ive thought about Meth and just spraying the front of the IC manually to freeze it before the burnout.....you're running great in da heat though.
Old 06-17-2006, 09:43 PM
kp
kp's Avatar
Hot weather really takes its toll on this car, it was only mid-high 70s and the track is 1600' or so. Plus spinning the blower faster heated it up a lot quicker. I think I'll just put the 3.7 back on and be done with it, if it runs 9.90 in the summer thats good enough I guess..
I dont think you want to spray straight methanol anywhere outside the engine, that stuff is pretty nasty..
Old 06-17-2006, 09:49 PM
onfire's Avatar
I worded that wrong...I meant spraying Meth into the intake or manually spraying N20 onto the IC right before the burnout...would make a nice cold heatsink...I just worry a little about metal fatigue.
Old 06-17-2006, 09:52 PM
Got Me SOM's Avatar
KP why not put the nitrous on and use a small shot just to cool the charge?
Old 06-17-2006, 10:50 PM
kp
kp's Avatar
I used nitrous on my old P1 car and anything less then a 50 shot didnt really make a huge difference. I usually dont go to the track when its super hot out anyhow - I hate hot weather
Car isnt running that bad really, a 6.14 with a 1.42 60' isnt all that bad at 3000' DA. When it cools off a little I'm sure I'll get it in the 5's..
Old 06-18-2006, 12:40 AM
URLOSN's Avatar
KP what is the smallest pulley they make for the D-1SC charger? 3.7, 3.4, ??? i am going to try and pulley mine for around 20-24 psi , and have never dealt with FI, and am learning. i have been following a lot of your posts, learning things. if you get rid of the 3.4 and it will work for what i am trying to do, and is 8 rib, i might get it from you. let me know
David
Old 06-18-2006, 08:49 AM
kp
kp's Avatar
Riechart will make any size pulley you want, but naturally you dont want to spin the blower too fast and the smaller the pulley the more chance for slip. Right now at 6800rpm I am at 59.5K impeller and 62K is tha max with a 7.25/3.4. A 3.2 would put it slightly over at 6800rpm.
I doubt you will get 20psi out of a D1 on an LS1, but with an F1x you probab;y could, but they have a higher internal step up ratio so you would run larger pulleys then a P1/D1. I'm going to spend a little more time with the 3.4 pulley on mine, track wasnt really hooking well so I'm going to give it another try next weekend at a lower elevation track.
Quick Reply: Hit the track last night with the 3.4 pulley and 2 more PSI
