solid roller cam for turbo
I also posted this in the internal engine section but im building a 408 with a pt88 turbo. Im looking for max power out the motor. yes its gonna be used at the track but i will hit the street time to time just to bait vics in. the hp im looking for is like 800+.Im looking for a cam spec proven to go with this set up. any help appreciated. thanks
Solid roller lets you get more valve lift area as well as more rpm.
I like mine, and I haven't had to touch the valve lash yet and I check it pretty regularly just to be certain.
Originally Posted by bumpin_records
what are the specs and what are you running
Another good bet would be www.camshaftinnovations.com.
Jay knows his stuff.
I cant say for FI setups but i run a solid roller in my old school 406 (306/298 .676/.670) and it has been driven on the street regularly. I cant say anything bad about and dont think ill ever build non roller motor again. As stated before i was having some problems with valve float plus with the SR you can run a MUCH more aggressive cam and it has better driving manners.
