Dyno vid of my ttvette
Old 06-30-2006, 09:20 PM
kindaslo's Avatar
Default Dyno vid of my ttvette
I'm out here in good o'l Tucson AZ
Motor is 408 stroker 8.5:1 comrpession built by larry's engine and marine
Turbo kit is hp eprformance twin 57mm installed and tuned by them, fuel system from them too.
110 degrees of ambient air in dyno shop netted the following numbers.
Little bit of tire spin on dyno
Old 06-30-2006, 09:30 PM
Blown SS's Avatar
Very nice !
Old 06-30-2006, 09:36 PM
Boostaholic's Avatar
How much boost were you on?
Old 06-30-2006, 09:46 PM
kindaslo's Avatar
8 psi 12degrees of timing and 91 octane
Old 06-30-2006, 09:57 PM
RealQuick's Avatar
nice!
Old 06-30-2006, 10:07 PM
Wicked_Hugger99's Avatar
That thing sounded badasp on the rollers plus very nice numbers at 8psi in the 110degree heat. I bet you got a whole lot more in it w/ more boost(obviously) & less spin on the rollers!!! What cam & injectors/fuel system you running??? Was the A/F looking ok???
Ditto to what 67Firebird455 said below as well!!!
Old 06-30-2006, 10:53 PM
67Firebird455's Avatar
Dude, you spun the **** out of the tires! LOL That thing sounds SWEET man, looks great too!!!
Old 07-01-2006, 05:33 AM
Got Me SOM's Avatar
I like it!! Car must be fun to drive!!
specs on your setup?
Old 07-01-2006, 09:15 AM
6 Second Club Moderator
LASTLS1's Avatar
It sounds nice! It should be a lot of fun.
Old 07-01-2006, 09:25 AM
Restricted User
NOSjohn's Avatar
Nice numbers, HP is doing some good work!
Old 07-01-2006, 12:03 PM
kindaslo's Avatar
comp cams 236/242 .600 lift ish i think... Can't remember honestly.
60lb/hr injectors motron i think.
Old 07-01-2006, 02:02 PM
seems more like a N/A or blower style cam than a turbo cam to me but whada i know, might be different w/ twins. Those 60LB motrons should be good up to 850-875rwhp or so i believe. Mine hit 851rwhp@17psi on C16 on a 248E chassis dyno. Think i could hit 775rwhp or maybe even 800rwhp on a load bearing dyno but anyway, i think my 60's were near being maxed out. Mine were at around 98% DC if i remember correctly. Im gonna move up injectors to whatevers best out there now once i get the 6.0L motor, T88(or bigger) and a th-400 conversion cuz i wanna run consistant mid 9s and hit 900rwhp locked like Tom Izzo's and/or Speed Inc's shop car turbo SS that did 907rwhp locked.
Anyway, good luck with that wicked vette and be safe!!!!
Quick Reply: Dyno vid of my ttvette
