t70 turbo max power
t70 turbo max power
what s the max power of a master power T4 Super T-70 in a rear mount? i have a stock short block 346 ls1 with forged pistons going in, automatic 02 ss. i would like to run 10-12 lbs of boost. what do you guys think. thanks
A/R Specs:
.70A/R High Flow Compressor Housing with 4"inch Inlet!!!!
.68A/R and .96A/R Turbine Housing T4 P trim turbine wheel
A/R Specs:
Originally Posted by 67Firebird455
I'm using that turbo, and the compressor map shows 84lbs, which is approximately 850 horsepower.
Originally Posted by Boostaholic
About 650hp at the flywheel is about what they will make. Plenty for the stock bottom end.
I run 9psi on 91 octane, but im sure I could run more.
Problem is size. The bigger 76 and 72 and 74 are all very large in size. Jose does have a new compact series of 70-76mm units though, so give us a call here at forcedinductions.com.
You might be suprised on the price of the compact units he has, plus they do have a real full 1 year warranty and no questions asked. I will say though e-mail him cause the phone is acting funny and we have had problems for the past few days receiving calls.
Why not just post up specs , info and price? It tis a tech board in all and you are sponsors....and the info will help those of us looking for better turbos right now.
Damn it I always get you and Jose mixed up Sorry bout that
But for under 1K and will support that kind of power...awesome. I'm not looking to break 1k but I'm in the market for a nice turbo for that amount of $$.
Right now i'm messing around with a T70 that is only temporary until I get a better unit.
Do you know if the turbo(s) in question are the/near the physical size of the T70-T76 turbo's?
I don't want to run a gigantor GT42 sized turbo again
They are a unit made by Jose and one of the T-netics eng's. We have been using and testing them for about 2 weeks now. Work awesome in small setups and have supported 1000hp crank with the newer turbine wheel fitted in.
