lifted a 6.0 head need info
I lifted the head on the driver side. When we went to take the head off the nuts that held it down seem too lose. We got the off using a 3/8 inch ratchet. When we took off the pass. side we had to use a braker bar to get those nuts off. Is it just because I lifted the one head or was it because the head was not tightened down it the first place.
ok I blew out the head gasket. First pass at the track after the motor was built. I was probably going off the rev limiter off the line but not going down the track.
6 Second Club Moderator
Originally Posted by nitrousboyWS6
22 degrees twin turbo set up pump gas 20 pounds
What hp level are you making with that set up? I would run 100 octane, at least. Pushing head gaskets suck.
Ya I think it was just too much timing for pump gas. I mean I had about 18 degrees of timing on the pump gas and went up to 23 degrees @ 11psi on pure race gas. Not a mix. It ran fine. But for pump gas IMHO thats a little too much.
I'd take it down to 18 at least, run more when u have 100 or over...but not much more. really timing isn't a HUGE factor in making HP boosted motors. better safe than sorry, but I guess u just found that out. sorry for ur luck.
now i could be way off as he hasnt posted back but did anyone think that he wasnt planning on running 20psi on pump...ie he had a problem controlling boost?i hit 20psi on pump a while back and probably would have had head gasket issue if i hadnt blown the maf off the car which shut the car off
Car was tuned at 20 psi on pump gas. I have an electroinc boost controller that was set at 20. Now that does not mean the car did not see more then that though when I was at the track and it blew out the head gasket.
I would also like to know why the head stud nuts were so loose when we took them off. Has anyone else had this happen after they blew a head gasket.
800rwhp and 725 rwtq though stock 6 speed moser 12bolt 410 gears at the time of the dyno pulls 373 now. compression is 8.6to1
