sts cam selection
Not really a solid answer to this. Ls6, GT2-3, GT-7, reverse split with mid 220's, etc.. It really depends on a few things. Do you want the most efficient? Sacrafice a little for some lope? Pass emissions?
We have used what most would say is a bad cam for a turbo; 224/230 on a 112, but we like it. We have a car in the shop now that has a 226/220 .570.564 115. It too works great and has a smooth idle.
Almost anything will improve power in the end.
Possible Scammer - Buyer Beware - Issues Unresolved
Originally Posted by navymitch12
i like my 224/224 .581/.581 114lsa
i called comp and they suggested to me a 224/228 581.581 114, pretty similar. what is your set-up
sts....t67, FMIC.....8psi
its funny because i got the cam from my step dad back when i was still NA and still loved it...and it just so happened to work out great with the turbo kit as well
http://www.exoticperformanceplus.com/movies/sts3.mpg
http://www.exoticperformanceplus.com/movies/sts1.mpg
http://www.exoticperformanceplus.com/movies/sts5.mpg
http://www.exoticperformanceplus.com/movies/sts4.mpg
http://www.exoticperformanceplus.com...Car.php?car=32
Check out the above video clips and our STS project car. Bob
I dont know if I call it mean and aggressive, but with a 224/230 .570's 112 cam, 402, stock 6.0 heads with good springs, Macs, TH-400, 12bolt, wrapped exhaust, T-70 it made 553 @ 7psi
Restricted User
Originally Posted by deadmanTA
longrange4u had good results out of a small lingenfelter cam. Think it was the gt2-3
dont have to pass emissions live in michigan just want something that sounds not stock but wont hurt the boost any answers, how about you bob cause i might be coming to you for tuning you just got doing my buddies 2002 camaro- f13 tune and his car is running great for all motor.
http://www.exoticperformanceplus.com....html?item=679 Here is our cam that was used in this car. Bob
Originally Posted by engineermike
I have never seen a power reduction by adding duration and overlap into a cam in a turbo motor. Quite the opposite, actually.
Mike
Mike
Originally Posted by 67Firebird455
If it's front mount on meth, or a good IC, then you wouldn't... But trying to spool a larger turbo out back without wrapping is a bitch. Have you seen a difference between cams when it comes to spooling the turbo on the same car?
Mike
