what Rad. are you guys using?
Old 10-17-2006, 07:35 AM
7 Second Club
ty_ty13's Avatar
Default what Rad. are you guys using?
im looking at on this one at summit racing http://store.summitracing.com/partde...5&autoview=sku
its a 27.5 X 15.5 and 3'' thick overall lengths.
right now my car idles at 210.... so after seeing Na$ty TA's car im going to setup my rad. like him and then ill have enough room to put the stock fans back on... .and still have a lot of room behind them for the d1sc.... and a f1c a year or two from now
Old 10-17-2006, 09:40 AM
NA$TY-TA's Avatar
Sorry i didnt get back to ya... kinda hecktic....
Yes that is the same one i have have.....
But i am not running a stock fan...... i am running a single 16" Spal fan rated at 2800 cfm and the car cruises at or below 185....
The last couple of days its been below 185 with the cool weather....
The day i got stuck in traffic for 2 hrs she never got over 200.
Let me know if ya need any pic's.
Kyle
Old 10-17-2006, 10:13 AM
T/A KID's Avatar
Kyle we need pics, I am wanting to cut the support on my LT1 car for my charger setup (not needed really, but I think it will may more room)
My car is a Street car, so I need it to stay cool.
Old 10-17-2006, 11:44 AM
2000slpss's Avatar
heres how i did mine.
Old 10-17-2006, 12:07 PM
T/A KID's Avatar
2000slpss looks good, let me ask you this, when you cut the support does the car want to flex or move??? I suppose you cut it while the car was sitting on the wheels instead of in the air???
Any tips, and did you use a Bi-metal saw? Looks good
Purevil I know has used his stock rad and fan setup and make over 800RWHP, I am thinking about using the same setup. I have been researching it all morning, know I have to go to chemistry, sucks, lol
Old 10-17-2006, 12:25 PM
7 Second Club
ty_ty13's Avatar
thats pretty much exactically what nasty ta did except he trimmed the place where the radiator sits...
Old 10-17-2006, 12:26 PM
7 Second Club
ty_ty13's Avatar
Kyle
can i get some pics with the fan mounted.... i want to see how much room there is between the fan and the motor (because i want to see how much clearance i have for the procharger).
thanks and you have a very beautiful setup.
Old 10-17-2006, 12:28 PM
7 Second Club
ty_ty13's Avatar
how much CFM do the stock fans move?
Old 10-17-2006, 01:00 PM
NA$TY-TA's Avatar
3400cfm....
Old 10-17-2006, 01:27 PM
NA$TY-TA's Avatar
here ya go...
This shows what was cut out of the bottom...
I hope that is enough pic's....
Kyle
Old 10-17-2006, 01:29 PM
Dragframe's Avatar
I have the same one as Kyle above me.... work wonders..... great product and is CHEAP.
Old 10-17-2006, 01:31 PM
PurEvl's Avatar
stock radiator, stock fans with a stock water pump..havent gotten around to putting my evans pump back on. Not that theres been a need, but i spent 500+ on it so its going back on dammit
Old 10-17-2006, 01:56 PM
7 Second Club
ty_ty13's Avatar
thanks guys.... looks like a lot more room! plus the radiator will be standin up straight.... i bet i gain atleast 3'' of clearance
Old 10-17-2006, 01:58 PM
NA$TY-TA's Avatar
I didnt have any fans after APE...
Old 10-17-2006, 02:25 PM
99SS-T's Avatar
The link that the original poster put up is the exact one i should get? I know there is cuttin and **** involved but i wanna make sure i get the right one. Definatly a great mod!
John
Old 10-17-2006, 02:43 PM
7 Second Club
ty_ty13's Avatar
yeah just measure the spot in your engine bay...
you can actually fit a 15.5 tall and a 29'' wide rad. but they only have the one above....
Old 10-17-2006, 02:48 PM
T/A KID's Avatar
From what I know the stock Lt1 radiator is better, but are they the same size. I think the stock rads are about 2.5-3inchs Longer and about 2inches taller.
What I am thinking is the stock rad and fans can be used in a Vertical setup?
Plus I was looking at summit and found these 3 rads with the same demision. The bottom one is the one with the link at the top, the other 2 look identical besides a 1 1/4 opposed to a 1inch Tube size.
http://store.summitracing.com/egnsea...+115&x=22&y=10
Old 10-17-2006, 02:51 PM
2000slpss's Avatar
the car was sitting on the ground when i cut out the core support and it didnt flex at all. wit hthe k member bolted up and the lower support still in its plenty solid. i just marked it off and used a cutoff wheel cuz thats what i had at the time. im sure there may be an easier way to actually cut it though
Old 10-24-2006, 09:27 AM
T/A KID's Avatar
Bringing this back, Kyle what is the part number for the Fan and shroud and where did you get it. I have a Daily driver and I plan on using that same radiator.
Your single seems to be working Fine.
Old 10-24-2006, 12:55 PM
7 Second Club
ty_ty13's Avatar
Kyle
he said its the same one i listed above at the very beginning.
Quick Reply: what Rad. are you guys using?
