370ci, T88 .96 AR T6 Flange T56 tranny
Old 10-20-2006, 12:56 PM
TINKRD's Avatar
Default 370ci, T88 .96 AR T6 Flange T56 tranny
will have 3.42 gears.
i've tried looking for compressor maps but cant find any online.
What RPM' do you think this will hit full boost at?
motor will be fully forged. if indeed there is alot of lag, i could always change the housing for it to spool faster, correct?
I was leaning towards a t4 flange, but my builder thinks that the bigger exhaust housing will aid in reducing backpressure and cut down on cylinder temps, detonation etc.
any thoughts?
Old 10-20-2006, 01:11 PM
LS1TECH Sponsor
DrTurbo's Avatar
You can find an 88mm map on this link.
http://www.forcedinductions.com/compressormaps.htm
Old 10-20-2006, 01:18 PM
obZidian's Avatar
Dr.turbo, you beat me to it!
Old 10-20-2006, 01:20 PM
TINKRD's Avatar
awesome, now if i can just figure out how to read it. lol
Old 10-20-2006, 01:32 PM
obZidian's Avatar
http://forcedinductions.com/consumption370.htm
this is your best friend right now!!!!!
its stated that it shouldn't be used as 100% representation, however, i have seen that the calculations are pretty close...
the top numbers are PSI and pressure ratio versus RPM on the left. The grided numbers are your lbs/min factors...
easy, just pick a boost, match it at your selected psi/pr... and see where that lies on the compression map. That site as has info on tips on reading the map..
good luck!!
Old 10-20-2006, 01:42 PM
LS1TECH Sponsor
DrTurbo's Avatar
Nicely done broh...... That will take care of it
Old 10-20-2006, 02:02 PM
TINKRD's Avatar
good luck!!
perfect! thanks!
Old 10-20-2006, 02:11 PM
NA$TY-TA's Avatar
With a 370 and a 88mm turbo you will be just fine....... I love mine.....
Kyle
Old 10-20-2006, 02:17 PM
LS1TECH Sponsor
DrTurbo's Avatar
S88's rule.....problem is we can't build them fast enough or get parts fast enough...lol. We are getting our own covers done though, so that will take care of the problem for the future.
Old 10-20-2006, 02:25 PM
TINKRD's Avatar
hmm...if i'm reading the map correctly for a 370ci and the t88, i'll be at 11psi at 4300rpms in the 78% range.
so is that 11psi full boost? i'd be at full boost 11psi at 4300rpms.
hmm... i wonder how much HP 11psi will make on a 370ci w/ a t88. is there a chart to convert displacement/psi to HP?
Old 10-20-2006, 03:01 PM
NA$TY-TA's Avatar
well lets put it like this...... I made 842 rwhp at 17psi thru a Powerglide and a 12bolt.
About 600rwhp at around 11-12 psi for me....
Kyle
Old 10-20-2006, 03:03 PM
TINKRD's Avatar
Kyle
was this on Meth??
i'll be seeing limited track time, but dont want a setup to where i can only highway race from a 70hit. I'd like to be able to go from 40mph, etc.
trying to have 800HP on pump gas for street driving, then turn the boost up for those special occasions.
Old 10-20-2006, 04:46 PM
AVB
AVB's Avatar
what do you divide if you run twins?
Old 10-20-2006, 06:23 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
With my 348ci + GT47-88 I was seeing 10 psi by 3500 on the 2step/trans brake.
Old 10-20-2006, 07:31 PM
NA$TY-TA's Avatar
was this on Meth??
Nope pump 93 and for me thats about as far as i want to push it on pump gas.......
Anything above 14 psi i run race gas.
Kyle
Old 10-20-2006, 09:53 PM
04mx's Avatar
NA$TY-TA what rpm are you fully spooled ive got the same turbo you have (s88) but i will have a 383 ci and was woundering what rpm spooling will happen ?
Thanks man
Old 10-21-2006, 05:07 AM
NA$TY-TA's Avatar
Thanks man
My Graph isnt right here in front of me... but off the top of my head id say 3800 at the latest....
Quick Reply: 370ci, T88 .96 AR T6 Flange T56 tranny
