10.206 @133 stock bottom end rear mount
Old 12-02-2006, 03:42 PM
1320's Avatar
Default 10.206 @133 stock bottom end rear mount
Last night, it was cold, DA was suppose to be around 1000 ft. I had to put on my smaller et streets cause the slicks were gone. On 11.5x 26x 16 et streets on stock camaro 16 inch wheels it went 10.206 @133 with a 1.505 60 ft.
This is a stock bottom end 99 camaro. used z06 cam, stock intake, stock throttle body, only missing the rear seat. It has a tube k member, lca, panhard rod, a 9 inch with 3.00 gears. A single 342 walbro pump. Still has power steering, power windows, heater, stock stereo etc. It has my rear mount turbo kit with intercooler, and a 76 turbo and 60 lb mototrons with my tuning.
It was spooling so fast I had to actually wait, instead of rush to stage and build boost. It goes from 0 to 10 in about 2 seconds. My best pass was wait for the tree so I wouldnt leave before the green, go wot, as the boost gauge was passing 6 psi let off the trans brake and I shift at 6000rpm. Oh it runs a th400 with a 3000 stall but goes about 3800 with @10 psi.
This winters projects......a twin turbo c5, and my own twin turbo 402 ls1 cobra replica.
Old 12-02-2006, 06:13 PM
99Z28LS1's Avatar
i love that. thats rediculous. your car IS amazing. i love that rear mounts are getting further and further down the line.
+1
Old 12-02-2006, 09:10 PM
Zombie's Avatar
My car broke by popping an I/C boot that night. Had a small leak since I was only seeing 12psi and boost was building slow. Managed a 10.6 @ 129.1 on a 1.59 60' I'm bummed since I was hoping to go low 10's. Next time...
1320 and I have very similar cars (he built mine).
Old 12-02-2006, 10:47 PM
Dbluegoat's Avatar
what's race weight of the car?
Old 12-02-2006, 10:52 PM
1320's Avatar
I dont know, its not light but not heavy either. It has a tube k member, welds on the front, missing the rear seat, the th400 and 9 inch (iron third member) turbo system, ps, pw, pb, stereo, oem carpet etc, stock seats, its a 99 hard top so no t top, and the console is out of it. It has ultra z glass hood (bolt on) and a ground effects and spoiler like the RS.
I d guess around 3400, which puts it at 3650 with me in it. It also had probably around 10 gallons of gas, cause 5 of it was 91 pump.
Old 12-03-2006, 12:00 AM
EGash's Avatar
Thats awesome! I'm glad to know a stock 346 will spool a t76 rearmount. Congrats on the times.
Old 12-03-2006, 02:11 AM
Mr_president's Avatar
im ready to see the video what do you dyno?
Old 12-03-2006, 02:18 AM
1320's Avatar
I dont have a video, my friend Will (benneliwang on here I bet) was suppose to go, but all I have is the fact that I built zombie s car also. His is alittle heavier and undoubtable will be faster in the same conditions if his entire car was as dialed as this 99. He has been in the mid 10's for while now, but with 3800-5500 ft da's not the once a year 1000 ft we had last night.
oh the 99 has been to a dyno in while, its last dyno was 553 with a 67 turbo. It picked up 4 mph with the 76 and no other changes and now 10 mph with other things fixed or dialed in better. Tires, traction, suspension, tune, exhuast leaks, etc.
Old 12-03-2006, 03:56 AM
longrange4u's Avatar
Nice man.... as you know our setups are very similar... I just have a PT88. I cant wait to see what she will do... hell if your getting those numbers. My 408 with the PT88 should see 9's easy...
Lemmie get a hell ya for us rearmounts pushing the limits.... and shuting up the doubters.
Old 12-03-2006, 05:19 AM
mattkimsey's Avatar
That's awesome - especially considering how much stock stuff was used.....stock heads?
Old 12-03-2006, 07:17 AM
DarkblueTA's Avatar
Sick times Jon! Congrads!
Old 12-03-2006, 09:21 AM
kp
kp's Avatar
Thats impressive with the turbo mounted anywhere
Congrats, you should tow that thing to a low elevation track in some nice cold air and see what it does..
Old 12-03-2006, 10:22 AM
1320's Avatar
west coast cylinder head ported 317's. 309 @ 600
Old 12-03-2006, 10:58 AM
frcefed98's Avatar
Nice! Its great to see another turbo LS1 knocking down some sick times.
Old 12-03-2006, 11:09 AM
LSs1Power's Avatar
Is that rear end gear ratio right? 3.00? Never the less great results.
Old 12-03-2006, 11:39 AM
Zombie's Avatar
Yup, his gears are right, I run 2.75's and he and I usually run the same times and are really close on the 60's. It seems that gearing doesn't make that big of a difference on a trans braked th400, except in driveability.
Old 12-03-2006, 01:58 PM
Frost's Avatar
I'm moving to 3.08s in my 12bolt with the TB'd th400 for the street life too.
Old 12-03-2006, 04:54 PM
Based off the problems Jermey was facing when he tried his PT88 I think I will stay with my 3:50 gears to help spool some.
Old 12-03-2006, 09:52 PM
Blackbird's Avatar
higher gears will make spooling worse, turbos want load, going 3.50 vs 3.00 your putting less load on the motor.
Old 12-03-2006, 10:16 PM
Frost's Avatar
Maybe true, but he's not gonna be spooling that thing on the bottom. He needs the RPMS to get it moving. I'd look at a looser stall too, one that without lockup won't be very street-friendly
Quick Reply: 10.206 @133 stock bottom end rear mount
