88 single on 346, spooling questions
Old 12-08-2006, 10:18 PM
datsbad's Avatar
Default 88 single on 346, spooling questions
I am putting all the peices together for my 98 , I am using truck manifolds and all my own stuff .
I was wondering if you think there will be any issues with spolling up a 88 on this thing. using some parts I have had for awhile and will be putting in a th400 with brake and RMVB. The converter I have is a 3500 , do you think it will be enough stall to get it spolled up and out of the hole good.
This is somewhat a street car but I am mainly concerned with track times.
Single digits are what I am shooting for .
what would be your choice?
76 or 88 ????
Old 12-08-2006, 10:23 PM
Turbo LS1 SS's Avatar
spool will be fine.. if its a track car with a brake, def go with the 88. theres at least 2 threads on this a week, do a ***search***
Old 12-08-2006, 10:25 PM
datsbad's Avatar
Thanks....search 88 I suppose?
Old 12-08-2006, 10:34 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,102 Likes on 723 Posts
T4 or T6 flange?
My T6 flanged GT47-88mm takes some time to spool up but I'm looking for 8's. I went 9.8@141 first time out.
Old 12-08-2006, 10:36 PM
...with cheese.
Armageddon's Avatar
If you can load up hard enough you shouldn't have a problem.
Old 12-08-2006, 10:37 PM
datsbad's Avatar
I was thinking of using the T4 flange . I just want to go 9.80's or so .
3500 stall enough ?
Old 12-08-2006, 10:40 PM
...with cheese.
Armageddon's Avatar
T4 Flange 88 will put you in the 9's and your stall should be ok IMO
Old 12-08-2006, 11:08 PM
datsbad's Avatar
little new on this but would that be a PTE-88? if not what ? This turbo stuff gets a little confusing if your completely up on it .
The GT47-88 is a T6 flange right ?
Old 12-09-2006, 12:53 AM
FormulaFire's Avatar
What's the biggest T4 flange turbo they make? anyone been 8s on a single t4 flange? w/out serious weight reduction? what are you weighing in at PSJ?
Old 12-09-2006, 09:41 AM
smokinHawk's Avatar
i have a 347 cubed truck manafold TA with a PTE88, ran a manual with it last season and am in the process of switching over to a Th400 with brake and a 3400 stall.
I saw 12psi about 4200, spool wasnt bad at all, i was just worried about shifting cause i didnt have much time to do it with the 3.73 rear gears.
mine is a street car as well.
that turbo has made it into high eights @ 3200lb car (think it was a 302 mustang)
so high nines would be no problem.
Old 12-09-2006, 10:28 AM
engineermike's Avatar
If all you're trying to do is dip into the high 9's, then a 76 has more than enough potential. You could actually back down to the 74 or 72 if you wanted to. These are physically much smaller than the 88, so they would be easier to fit. Just don't make the mistake of getting the GTQ or on-center exhaust sides. Tang GTS will get you there easy.
Old 12-09-2006, 11:44 AM
smokinHawk's Avatar
the PTE88 isnt much bigger then a t76gts size wise, ust the exhaust housing is a little bigger and fits a 4" downpipe.
Old 12-09-2006, 12:39 PM
datsbad's Avatar
so is the generous consences telling me that if I want a 4" DP and a smaller frame to go with the PTE88 , T4 flange . centered, what size ar?
Old 12-09-2006, 01:14 PM
LS1TECH Sponsor
DrTurbo's Avatar
You can get a PT88 with a different Tang V housing as well though and you can run either a 3" or 3.5" dowpipe as well, so don't forget that.
Old 12-09-2006, 01:29 PM
longrange4u's Avatar
Thats a PT88 From Forced Inductions... fit under the back of my car...
Old 12-09-2006, 02:39 PM
LS1Tech Co-Founder
My GT47-88 (Which are all T6):
http://psj.ls1tech.com/gallery/main....avId=xace3ea65
http://psj.ls1tech.com/gallery/main....m&g2_itemId=26
Old 12-09-2006, 03:18 PM
smokinHawk's Avatar
yes, i think the PTE88 is the largest T4 flanged turbo you can get, least it was when i bought mine.
and like mentioned about you can get it with different exhaust housings
mine was the tangental t4 flange with .96 AR and a 4" downpipe connection
Ive seen one guy have a PTE88 with a T6 flange as well.
Old 12-09-2006, 03:45 PM
blacksheep's Avatar
I've got a mid frame GT47-88 w/ a T-4 that Precision made and its for sale. Patrick at Precision said it would support 1400hp as long as it had a 4in DP.
Old 12-09-2006, 04:13 PM
It's enough bigger that it won't fit in place of my T76GTS. Also, the 76 will spool quicker than the 88.
Old 12-09-2006, 04:54 PM
otherwhitemeat's Avatar
__________________
yes, now a days you can get a large frame turbo special made with a t4 housing.
Quick Reply: 88 single on 346, spooling questions
