Guys With 6.0 Iron Blocks Come In
Old 12-09-2006, 07:28 PM
MiaSSmaro98's Avatar
Default Guys With 6.0 Iron Blocks Come In
Well A Buddy Of Mines Was Gonna Build A 1000hp Turbo Vette Using A 6.0 Iron Block,hes Having Lots Of Problems Lately And Wants To Give The Block To Me.now I Need To Know A Few Questions About It
-how Much More Does It Weight?
-what Will Be The Displacement On It?
-is Everything From An Fbody Ls1 Interchangeable?
Old 12-09-2006, 07:33 PM
single digit dreamer
parish8's Avatar
i have heard 60lbs more and i have heard 80lbs more.
displacement depends on your bore and stroke. anywhere from 363 up to 434(i think). most people either go stock crank .030 over for something like a 368ci or with a 4" crank and .030 over for a 408ci
everything bolts right over.
Old 12-09-2006, 07:38 PM
2002/Black/SS's Avatar
yup its weighs 70 pounds more then ls1
stock displacement is 364 or 368 i dont remember
but he probaly bored it alittle so id guess 370
and everything will swap with it
HydroStream6's Avatar
LS1Tech 10 Year
It is about 80lbs heavier. Everything bolts right up.. but I did run into one snag when swapping mine over. My oilpan on my GTO has the provision for the oil dipstick. SO when I installed it I put it in there. Little did I know the 6.0L iron block has the dipstick hole in the side of the block, so when I went for my first drive, I had oil everywhere. You will have to cover that hole.
Parish is right on with the CI options... I chose to stick with the stock crank and a .030" overbore which is 370ci.
Old 12-09-2006, 07:43 PM
Okay So 30 Over Will Be 4.?? Piston Size
Old 12-09-2006, 07:53 PM
HUNTER02SS's Avatar
I think you also have to drill and tap a hole for the third altenator bolt.Not a 100% sure.
Old 12-09-2006, 08:10 PM
trtturbo's Avatar
you will have to drill and tap one hole in the front for the alternator bracket.
To get your C.I. you multiply stoke X bore X bore X .7854 X 8(number of cylinders)
I think it is around 80lbs heavier also
Old 12-09-2006, 08:59 PM
Possible Scammer - Buyer Beware - Issues Unresolved
00ls1's Avatar
you have to drill a hole for the power steering bracket
Old 12-09-2006, 09:30 PM
LS1Tech 10 Year
4.030" bore with stock LS1 crank is a 370.
Stock 6.0L truck engines come in at 364.
On my 04 GTO, I didn't have to drill any holes to swap everything over, just the dipstick plug as I mentioned above.
Old 12-09-2006, 10:59 PM
yeah so i guess i will need to check for the bracket bolts
Old 12-10-2006, 05:46 PM
Firechikn's Avatar
If you bought a short block built already, the hole is already drilled and tapped for you. But if you bought a bare block out of a truck or from GM, then you have to drill the hole. I'll save you some trouble and buy the block from you. I'm in the market for one tooooo.
Old 12-11-2006, 02:05 AM
i'll see what i do
Old 12-11-2006, 02:07 AM
BIG BAD BLACKSS's Avatar
Is drilling for the alternator for GTOs only, i havnt heard of this before for the f-bodies?
I have a iron 370 im putting a procharger on. There is one bolt hole missing on the iron block that the blower bracket uses. So you have 2 bolts holding the blower on instead of 3. No one has reported a failure yet, but it doesnt leave ya feeling too confident. Supposedly you can drill and tap the lock for this hole, but it seems like an extremely delicate procedure if its possible at all.
Old 12-11-2006, 02:48 AM
JustAnIlluzion's Avatar
it is not that hard, u should do it ASAP.
Old 12-11-2006, 06:28 AM
LS1Tech Sponsor
Slowhawk's Avatar
Thats the hole you have to drill
Old 12-11-2006, 10:56 PM
WhiplashDVD's Avatar
i noticed one thing on my 6.0 block, there are only provisions for 3 of the altenator bolts. the 4th on the top left looking from the front has no spot to bolt anything to.
Old 12-11-2006, 11:47 PM
Pathological Modifier
Ryan K's Avatar
Old 12-13-2006, 12:02 PM
yes thats what i mean, 4 bolts were holding my alt including the side one. Now only 3 bolts including side hold the alt with the 6.0 block. Do you think attachment at the top left is vital?
Old 12-13-2006, 06:48 PM
HUNTER02SS's Avatar
Originally Posted by Ryan K
Picture's are better than word's in some cases.This is definatley one of those cases!
Old 12-14-2006, 12:21 AM
Shorty Director
VINCE's Avatar
It's only the weight of a 8 to 10 year old passenger. I have one..
Quick Reply: Guys With 6.0 Iron Blocks Come In
