408 truckmanifold kit
Old 01-21-2007, 11:05 AM
B18CYA's Avatar
Default 408 truckmanifold kit
well I started thinking about putting a stroker crank into my 6.0 iron build the only concern I have is the flowing capability of the 2.5" crossover and the manifolds. I have already decided against large tubular headers for a couple of reasons and was wondering if any of you have done such a big motor with the truck manifolds.
fyi on setup 370" S80 t6 flanged 4"dp and exhaust, ported heads, ls6 intake
Old 01-21-2007, 12:57 PM
SELLSZ06's Avatar
check out one of the stickys thread.
Old 01-21-2007, 02:13 PM
frcefed98's Avatar
They'll flow enough, if you are worried about the crossover, make it 3.0 instead of 2.5.
Old 01-21-2007, 02:26 PM
02SSLE's Avatar
I ran 3 inch crossover on my new setup
Old 01-21-2007, 02:50 PM
black98ws6ta's Avatar
The biggest restriction is at the turbine housing, running 3'' wont change anything but maybe make it spool slower. The 6.0's have worked great on larger motors then you are considering running.
Old 01-21-2007, 05:26 PM
B18CYA's Avatar
did you notice any difference with spool?
this is a tang t6 flange should flow nicely
Old 01-21-2007, 05:32 PM
B18CYA's Avatar
what size crossover did you run?
Old 01-21-2007, 05:34 PM
2.5 is the most common. The exit at the 6.0l manifolds are around that size, and when you neck it down at the compressor housing. Even a t6 flange/exhaust housing doesnt outflow (2) 2.5 pipes.
Old 01-21-2007, 05:37 PM
TwnTrboCE's Avatar
We have ran 2.5" on our 408 to 1500+ hp. We'll be running 2.5" on our 427 also.
Old 01-21-2007, 05:40 PM
B18CYA's Avatar
oh goody!
408 here we come!!!!!!!!!!
Quick Reply: 408 truckmanifold kit
