Breaking in turbo engine with turbo or without?
Old 03-18-2007, 06:39 PM
Snyper's Avatar
Default Breaking in turbo engine with turbo or without?
Ill be breaking it in on the street...should I break it in with the full 12psi..or start out with 4 and work my way up? I like the "moto" method..but it doesnt seem like it would be safe to break it in like that throwing 12psi at it. Any suggestions?
Old 03-18-2007, 06:57 PM
engineermike's Avatar
full 12
Old 03-18-2007, 07:02 PM
52172's Avatar
full 12 seat the rings
Old 03-18-2007, 08:06 PM
ninety4three4's Avatar
that is the only way you are going to make full power once it is broken is to let it feel the boost otherwise like 52172 said you will have excessive blow by problems...good luck with it
Old 03-18-2007, 08:48 PM
Snyper's Avatar
Hit it with 12psi off the bat?...I wont ruin the rings by throwing that much boost at it off the initial start up? I was told a bunch of different things like running with the turbo unhooked, or run 4psi for a few hundred THEN 12.. I know the moto method says to beat on it..which is why I was hesitant to throw 10psi as it off the bat. Anyone wanna explain in detail how they broke theirs in?
Old 03-18-2007, 09:09 PM
I've done 3 so far at 12+ psi. On another one, we broke it in at 3 psi on the dyno, but that wasn't on purpose. We were having trouble with the wastegate. It would've been at 12 also if we could have.
Old 03-18-2007, 09:13 PM
i am speaking from expeirience with diesels and the only way to seat the rings properly is to run the engine after initial cam break in at full throtle for a extended period of time on the dyno under load, if this is not done their you will have blow by issues and you will not make your full power potential but again i am speaking from a diesel standpoint so your best bet is to contact a well known turbo shop or something, hope that helps
Old 03-18-2007, 09:44 PM
z28adiction's Avatar
Ive always been told to run it at the boost level the engine will be seeing. Like everyone else said becuase of blow by issues and to seat the rings. But best bet is to call a turbo specailty shop and ask.
Old 03-18-2007, 10:04 PM
Snyper's Avatar
so...set everything up how im going to run it..get it up and running right and then take it out (i have a 5 mile straight back road)..and just beat the **** out of it?
Old 03-18-2007, 10:57 PM
ninetres's Avatar
I asked texas speed....who i bought my block from, and they had a pretty thorough answer that DID NOT involve high rpms or full throttle for at least a couple hundered miles.
I would ask whoever you got your block from.
Old 03-19-2007, 12:12 AM
SuperZ's Avatar
i started off with the 5psi spring for the first hundred or so then worked my way up to 15ish.Its been fine for the last 2 years like that.
Old 03-19-2007, 05:50 AM
Snyper's Avatar
how exactly did you break it in? take it out and beat the hell out of it?
Old 03-19-2007, 11:22 AM
Snyper's Avatar
btw..I have plasma moly rings...does it make a difference?
Old 03-19-2007, 11:27 PM
FastKat's Avatar
My biggest concern will be getting all of the bugs out of the system after startup... I would imagine you're going to have less startup issues running it at a lower PSI. Talk to whoever supplied your block FTW.
Old 03-19-2007, 11:31 PM
mahhddgtp's Avatar
I've heard lots of load (higher gear), WOT until a certain RPM... but that maybe for just NA cars..
Old 03-19-2007, 11:35 PM
Pathological Modifier
Ryan K's Avatar
As long as your tune is right on then break it in under boost, BUT if you don't have your tune set already, then DON'T...
Quick Reply: Breaking in turbo engine with turbo or without?
