Cog setup on the street???
Is this doable at all? I dont daily drive the car but i do drive to the track and go to a lot of GTG's (2 a week maybe when the weather is good). Those belts are kinda expensive to be replacing all the time ... If not what else? 12 rib? Who sells a setup that will work for me??? This will be a F1R setup by the way...
I don't know of any cog systems by anyone that are available for the LS1 F Body's. I also haven't seen anyone convert one to a 12 rib. There isn't much room under there... Bob
Andrew used to drive his car with a cog belt setup Josh.
I know speed inc had a cog set up on there D1 way back in 02 or so......I have seen a few guys try to run them on the street and they would rip through belts and they are not cheap. So to answer your question no I have never seen a street car do so with great success
Originally Posted by xssive
ATI jsut released a dampener/pulley system for cog/10/12 rib setups on ls1s
http://www.atiperformanceproducts.co...-kit/index.htm
I looked into their cog system (nice - it has a clutch). But it's 3" wide! My 8 rib is jut over 1" and it's a tight fit. So while I want one, I'm not going to cut/move/weld the radiator support forward 2" to make it happen. There is probably room for a 12 rib, but nobody makes a kit.
Originally Posted by slowredz
Thanks man I will probably give them a call in the morning...
If you need something from ATI let me know. Chris is a dealer of theres now, and we also are sponsored by them.
Originally Posted by V6 Bird
Let me tell you this bro...With the box that just showed up at Ray's shop with someones blower in it...Theres a cog setup in there Its sweeeeeeet too
(edited)
