Guys running large injectors (83 or bigger) on stock computer...
Old 05-02-2007, 12:33 PM
ABeasst's Avatar
Default Guys running large injectors (83 or bigger) on stock computer...
Please leave this in here so I can get some help with my turbo tune. Any chance someone with large injectors can take a look at my tune file or send me their tune to help me figure out why it wont idle or cruise lean.
I've tried everything I can think of and I cant seem to get it to work.
thanks.
Adam
beasst@bellsouth.net
Old 05-02-2007, 12:35 PM
6SpeedLT1's Avatar
thanks.
Adam
do you have a versafuler or anything controlling it? and what type of file is it?
Old 05-02-2007, 12:41 PM
98turbls1's Avatar
he'd have to, if he didn't then he'd burn his PCM up almost immediately...
Old 05-02-2007, 12:53 PM
ABeasst's Avatar
I have the AEM injector controller and its an HPT bin file.
Old 05-02-2007, 02:53 PM
cablebandit's Avatar
try changing the short pulse adder to -.3 (yes minus) all the way across and see if that helps
Old 05-02-2007, 02:58 PM
ABeasst's Avatar
it helps at part throttle but not at idle.
Old 05-02-2007, 04:15 PM
98turbls1's Avatar
One more post ABeasst and you got a 1000!!!!
Old 05-02-2007, 07:00 PM
my 96# will idle at 14.7....you got something else not right in the tune yet
Old 05-02-2007, 07:03 PM
98turbls1's Avatar
candlebandit are you on the stock pcm with a converter box??? Maybe the box isn't working right??
Old 05-02-2007, 07:53 PM
yes....i bet its not the box
Old 05-02-2007, 08:06 PM
98turbls1's Avatar
Oh me too... it's most likely (99%) in the tune... Do the versafueler and AEM box have the same parameters for tuning?? i've never really messed with one but I have looked at the versafueler before but just never got that in depth with it....
Old 05-02-2007, 08:20 PM
ABeasst's Avatar
I turned on closed loop LTFTs and re-scaled the injectors and it helped at cruising and part throttle but still no help at idle. Are any of you running closed loop for STFTs?
Old 05-02-2007, 08:33 PM
im olsd
Old 05-02-2007, 08:41 PM
GTFORMULA's Avatar
Cablebandit I will be running 96#ers when I get my car running . Who around the south is the best tuner for crazy forced induction?
Old 05-03-2007, 04:52 AM
i dunno...i do my own
Old 05-08-2007, 12:06 PM
ABeasst's Avatar
UPDATE: I figured I would give an update to help anyone in the future trying to get big injectors to idle and cruise with HPT. I have got the car idling and cruising around 13.5-14:1. I ended up changing:
*the short pulse limit to 1.44 so it would not add any fuel except at idle.
*rescaled the short pulse adder
*I lowered the min. injector pulse and default injector pulse.
*rescaled my entire EQ ratio table for open loop (no longer 1 like it was originally)
thanks to everyone that helped, especially Slowhawk.
Old 05-08-2007, 12:49 PM
KraZy's Avatar
Awesome, thanks for the update!
I cant wait to see the car running, I know its been a PITA. You'll have to let me know when you take it to the track.
Quick Reply: Guys running large injectors (83 or bigger) on stock computer...
