Single GT-K 1000 turbo 383
I'm getting my combo narrowed down. I have decided to go with the slightly smaller Turbonetics GT-K 1000 vs. the Precision T-76 GTS in favor more low end power (faster spool). I will be putting it on a LS1/LS6 based 383 stroker. I am leaning towards the Lingenfelter GT2-3 / GT-7 cam and around 9:1 compression. Intercooler will be an air-to-air w/ Alky Control methanol injection. My goal is 750+ rwhp.
Anybody see anything wrong with this combo? Could I run more compression (9.25:1) or would you suggest less? Which cam would best suit this combo, the GT2-3 or the GT-7?
Also, what would the turbo guru's extimate the full spool to be w/ 10-15 lbs of boost?
it could it be that your 76 is making positive boost by 2500rpm
it could be spooling much sooner positive manifold pressure and spooling is 2 different things ....correct me if im wrong but that seems to be the case
i would think you would need a 80mm and a .96 ar on the exhaust side
