How much power will twin 2.5" IC tubing support?
Old 05-06-2007, 05:33 PM
ttcamaro's Avatar
Default How much power will twin 2.5" IC tubing support?
This is for my twin turbo setup. I was thinking of doing 2.5" out of each turbo into the intercooler then go 4" out of the turbo to the T-body. anyone know how much power this will support?
Thanks
Old 05-06-2007, 06:55 PM
Boo"SS"t's Avatar
How big are your turbos? t4's or t3/t4's? I would imagine that as long as you don't go smaller than the compressors I.D.'s outlet it should be able to support what your whole set-up could produce (just remember that you'll have two of them = 5"), and I'm assuming you meant 4" from I.C. to T.B.??..which is plenty big (same O.D. on T.B.'s).
Old 05-06-2007, 07:20 PM
HUNTER02SS's Avatar
That is what I am using! No restriction's yet!
Attached Thumbnails How much power will twin 2.5" IC tubing support?-finished-turbo-kit-photo-s010.jpg
Old 05-06-2007, 07:31 PM
Turbo Tech's Avatar
1000's
Old 05-06-2007, 07:55 PM
qqwqeqwrqwqtq's Avatar
Good answer
Old 05-06-2007, 10:58 PM
ttcamaro's Avatar
ok cool thanks. Ill post pics soon
Old 05-07-2007, 03:05 AM
2MuchRiceMakesMeSick's Avatar
wow your setup looks great and great numbers too
Old 05-07-2007, 10:00 PM
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
More then the motor will ever be able to handle.
Quick Reply: How much power will twin 2.5" IC tubing support?
