valve spring sizing and boost
Old 05-21-2007, 08:58 AM
pwrtrip75's Avatar
Default valve spring sizing and boost
I have a 224/224 .580/.580 lift cam and run 15psi. I broke one of my old dual PSI springs and am going to buy new ones.
Will the comp 918s work fine? I know they would with out boost. But is that 15# going to matter?
any other recomendations if they dont work?
thanks.
Old 05-21-2007, 10:46 AM
JAvenger007's Avatar
why not patriot golds?
Old 05-21-2007, 10:56 AM
Zombie's Avatar
I floated the valves with my 918's and 14psi, go to a stronger spring.
Old 05-21-2007, 11:15 AM
RW99's Avatar
I just went to the Patriot Gold duals and it helped me solve some problems above 4500 rpm... re-tuned, at 11 psi or so, I made 30 more rwhp and rwtq. I'm glad I did it. The cam is nothing special: 224/224/114, 0.588.
Old 05-21-2007, 12:18 PM
pwrtrip75's Avatar
because i have no idea what they are.
Old 05-21-2007, 01:30 PM
Fiery Features Director
Zangel's Avatar
I had the same problems and switched to the Patriot springs.
http://www.ls1speed.com/catagory.cfm...in%20/%20Heads
Old 05-21-2007, 02:07 PM
2001WS6Vert's Avatar
Since upgrading from a T-trim to a YSi I have been trying to work out high RPM mis-fires (I have 918's). I thought I had it solved when I raised the MAF Hz to 16000 (couldn't hardly get past 6000 until I did this). I go right up to the 6800 rev limit now but it still is doing weird things up top. I think I'm going to be switching to the Patriot duals.
Old 05-21-2007, 03:01 PM
Patriot Performance Gold Dual springs. Check EPP for some details and price. TRT also sells them. Typically $230-250 and they are dual springs that come with Ti Retainers, seals, locks, and machined bases and support up to .660" lift
Old 06-08-2007, 07:11 PM
Cheatin' Chad's Avatar
thanks.
If you are running a maximum of 15lbs of boost and your heads have 1.94inch intake valves (for example). Your springs would require an extra around 45-50lbs (theoretically) of additional pressure from the spring to control your valve motions while under full boost. Not having that additional spring pressure MAY cause your valve to not fully close against the seat. This CAN be catastrophic...
A spring like the COMP 918 would be able to control the cam you are running in most N/A instances.
COMP 26918
130@1.800"
333@1.150"
So,adding the additional poundage required due to boost you can figure on using a spring in the 380 @1.15 range.
Springs that should work for you:
CompCams 26921 Springs;
O.D.: 1.300
I.D.: 0.655
Seat Load: 135
Open Load: 400
Coil Bind: 1.040
Rate (lbs./in.): 408
Patriot Gold Springs;
O.D.: 1.290"
I.D.: .675"
Seat Load: 140
Open Load: 380
Coil Bind: 1.090"
Rate (lbs./in.): ???
Of the two the patriots are cheaper and have a great track record. I have also heard nothing bad about the 921s but they are pricey.
Either of those springs will offer you a bit of "working room" with the cam/boost combination you have.Well, that is assuming you have a valve size near 1.94in anyway...
The figures I've presented as your requirements are not exact,they are rough estimates of what you would need on the more extreme end but you should have ZERO problems with either the 921 or Patriot Gold spring.
I hope that helps.
Old 06-09-2007, 03:52 PM
RW99's Avatar
Now that is one frickin' helpful post. Gold star for Cheatin' Chad.
Old 06-09-2007, 04:31 PM
how would 918s fare with 8psi and a 228/228 .588 .588 115LSA cam. Would they hold 10psi? Is it vital to swap to ti retainers or any of that? my 317 heads came assembled with stock stuff but still new.
Old 06-09-2007, 04:45 PM
Josh@KY-Turbo's Avatar
I currently run the 918 at 10lbs. I am going to switch to the Patriot Golds soon and before turning up the boost. The extra insurance is worth it.
Old 06-09-2007, 05:14 PM
Did you ever see problems at lower boost with the 918s and do you have any now at 10psi? Or are you just swapping for added insurance?
Old 06-09-2007, 05:37 PM
I havent had any problems so far. I just want the added insurance with more boost and RPM. I have taken the 370 to 6500 a couple times with no worries on 10lbs.
Old 06-09-2007, 08:29 PM
Losing weight in your retainers,locks,and valves will reduce demands on the springs. All things being the same you will improve valve control for a given spring rate by reducing "sprung" weight.
To give you exact figures I'd need to know your intake valve size,camshaft specifics,etc. If you do a rough estimate based on the information I provided earlier you will be able to get yourself in the ballpark.
Based on the information provided (and assuming on everything else) I would say you are probably marginal.I believe It is better to err on the side of caution concerning valve control.
Old 06-09-2007, 08:30 PM
Thanks
Old 06-11-2007, 08:50 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
My car:
Crane 832's at 17 psi, 700rwhp or so
Comp 921's at 18-21psi, 746rwhp or so
ETP Springs at 24-26 psi, 867rwhp or so
My Crane 832's worked very well until I went to more camshaft (went from 230/236 to 236/246).
Old 06-11-2007, 09:01 AM
Shorty Director
VINCE's Avatar
My car:
That is a lot of boost John...
Old 06-11-2007, 10:27 AM
LS1Tech Co-Founder
I have a little old 8:1 348ci, I'm guessing my motor makes like 350rwhp NA.
