Gauge ?
Old 05-30-2007, 06:45 PM
2002BLKTA's Avatar
Default Gauge ?
hey guys,
I know its been done but i cant seem to find any info, so im just going to ask what gauges are the people who are running the gauges in the heater vents above the stereo using?
here is a pic of the vents i want the gauges in?
Thanks
[IMG][/IMG]
Old 06-03-2007, 10:01 PM
TAaddict's Avatar
I was wondering the same thing. I can't remember where, but I have seen the gauge set-up in the vents and it looks a lot better IMO. Anyone have any info?
Old 06-04-2007, 10:09 AM
RW99's Avatar
Get an Eboost2 and it'll fit nice and tight in one of those spots. And that's important for that particular gauge, because you'll be pressing buttons on it to set it up and cycle through displays once you're up and running.
For other (smaller) gauges that you won't be touching, careful removal of the vent vanes along with some dremel work will allow you to use the original insert piece as a collar for your gauge. Usually some sort of spacer will be necessary to wrap around the gauge itself to fit it tightly to the collar; I tried a couple different sizes of black speaker wire until I got a good tight fit.
Old 06-04-2007, 12:16 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I am running my aeroforce interceptor gauge (2 1/16") in my center vent location. I need to get some pictures...
Old 06-04-2007, 01:04 PM
Firechicken1995's Avatar
2 5/8" gauges fit in those vents perfectly my 2 1/16" boost gauge its too small and required a "filler".
Old 06-04-2007, 01:08 PM
52172's Avatar
Funny everyone spells gage gauge. Gauge should be used like 12 gauge shotgun or 8 gauge speaker wire. Look on your GM dash and when your fuel gets low it says check gages. Not to be a dick or anything just something I noticed.
Old 06-04-2007, 01:14 PM
romulo13's Avatar
From Wikipedia, the free encyclopedia
A boost gauge is a pressure gauge that indicates manifold air pressure or turbocharger or supercharger boost pressure in an internal combustion engine. They are commonly mounted on the dashboard, on the driver's side pillar, or in a radio slot.
I don't know what my dash says, but I did a search.
RW99's Avatar
I will refer to Webster instead of GM:
GAUGE 2 : an instrument for or a means of measuring or testing: as a : an instrument for measuring a dimension or for testing mechanical accuracy b : an instrument with a graduated scale or dial for measuring or indicating quantity
My guess is that it's a GM typo that they've been too embarrassed to correct! But, to be fair, "gage" is also a variant spelling.
More than anyone wanted to know, I'm sure.
Old 06-04-2007, 01:53 PM
52172's Avatar
Great research guys! Did GM really mispell on their dashboards? Maybe both spellings are correct???
Old 06-04-2007, 02:51 PM
koolaid_kid's Avatar
No, they saved $0.0003 per car by omitting the extra letter.
Old 06-06-2007, 10:19 PM
RW99's Avatar
Took a quick pic with the phone...
Kinda gives you the general idea. If you want a high quality look to the install you're going to need to find/fabricate some sort of bezel trim piece to fill in the gap around the gauge... especially for the small gauges. I'm not too fussy about the appearance, obviously.
