Injectors for the STS?
I was just curious if anybody knew what injectors would be best to run with an STS set-up with intercooler and about 5-8 psi. I know everybody seems to be running the 42lbs, but does the type really matter? Should I spend the $450 on the Ford Motorsports, or just go with an e-bay Bosch for about $300? Any inputs? Also, the STS website talks about running a fuel pump booster. Has anybody actually tried running that instead of a larger fuel pump?
Heres what I did and I'm sure many others would recommend this as well. Just get a racetronix kit and 60lb injectors. They sell for $400 from sponsors and ebay. If youre making 550+rwhp then you'll need new rails and a BAP.
go with the 60's, they'll give you some room to work with. I am running the BAP with a single walbro, i'd say just replace the stock pump so that area will also be covered.
I'm running 42#ers rated @43.5psi (being run at 60psi) and I have a duty cycle of 65% made 423HP and 431TQ.
going to go to 7psi w/ IC soon
get the Racetronix PnP kit... you will be set and later you could add the BAP if you needed it. i'm going to see what these 42#ers got and i think they will be fine even at 7psi
