Speed Inc. shop car update
Old 07-17-2007, 08:53 PM
qqwqeqwrqwqtq's Avatar
Default Speed Inc. shop car update
I'll post up some pictures tomorrow, but here and there we've been working on our shop car. Current setup is-
383ci 6.0 iron block, Callies crank, oliver rods, CP pistons, 10.0-1 compression. Out of the box ET 235's, stock LS2 intake, 90mm tb.
Cam is a 240/240 112lsa hydraulic roller with comp stock replacement lifters.
Turbos are twin Innovative GT72 ball bearing P-trim, .82 a/r. Intercooler was built by Dan with a 24x12x6 air/air core from Bell. Exhaust is dual 3.5 downpipes into Borla mufflers ending just ahead of the torque arm crossmember.
Rossler T400 with Neal Chance bolt together converter.
9in with 3.25 gears.
We had it mini-tubbed and are running 325 50/15 ET street radials.
First run on the dyno pushed out the Titan ICS copper gaskets so we threw on some GM MLS and brought it to the track. Just going from memory it ran 8.9 @ 156 with 17psi boost, leaving easy.
We've since changed the 234/234 113 cam to it's current 240/240 112 cam and had the converter tightened up as we were getting about 15% slip.
On the dyno today it made-
882rwhp @15psi, and
1,144rwhp (spiked to 24psi and held steady at 20psi) Ran it up to 7,850rpm and power was just barely starting to fall off.
If all goes as planned we'll be making some more runs at the NMRA/NMCA thing at RT66 in Joliet this weekend in the Real Street class. Should be fun
Old 07-17-2007, 08:55 PM
JMBLOWNWS6's Avatar
Wow that car is going to be a monster! What are your expected times of it in the 1/4?
Old 07-17-2007, 09:12 PM
LS1 SPEED's Avatar
I would think the power is there to go high 7's, but we would be more then pleased being in the lower 8's. We just have to get it to the ground.
This is a street car with working radio and the only weight reduction mod was the A/C. I am sure the TT system, and cage more then make up for that though.
This weekend is looking to be great weather and with a good track it should be interesting.
Jim and Dan have worked hard on this car over the months...great job guys
Old 07-17-2007, 09:13 PM
theblur98ss's Avatar
sounds like a strong setup. Why the 10-1 compression though?
Old 07-17-2007, 09:15 PM
Actually, I think the car would need another 250-300hp to run in the 7's, but I would be happy if it ran sub 8.50's.
Old 07-17-2007, 09:16 PM
LS1 SPEED's Avatar
probally right...thinking of those low race weight Stangs with similar HP
Old 07-17-2007, 09:23 PM
Z8'S's Avatar
What is the raceweight? Have you ever weighed it? I was there when it was dyno'ed sounded awesome .Good luck this weekend.
Old 07-17-2007, 09:27 PM
Q8CamaRo's Avatar
excellent job guys .. thats the way Speed inc. is .. keep it up
Fahad marei
Old 07-17-2007, 09:30 PM
JMBLOWNWS6's Avatar
OK so now we need a video!
Old 07-17-2007, 09:31 PM
Thanks guys.
Chris, Dan did weigh the car but I do not remember what it was.
LS1 SPEED's Avatar
hope to get some good video this weekend
Old 07-17-2007, 09:33 PM
99Z28LS1's Avatar
sounds awesome, so yeah...... why the 10.1 comp?
Old 07-17-2007, 09:58 PM
venom ws7's Avatar
10.1comp and 20psi wow awesome work guys.
Now we need alot of pics and vids.
Old 07-17-2007, 10:08 PM
More power and response.
Old 07-18-2007, 12:00 AM
NA$TY-TA's Avatar
Thats what i was gunna add.... no reason not to if she is always running on Race gas....
Old 07-18-2007, 12:01 AM
otherwhitemeat's Avatar
two T72's should make close to 1500hp ???......turn it up!
Old 07-18-2007, 12:06 AM
domination's Avatar
Love your work guys. This car should be sick. I have long been a fan of higher static compression and boost. Its kinda like nitrous. People hear horror stories of how bad it can be from others that have melted engines and don't want to mess around with it at all. Done properly it will net you as you stated, more power and alot better responce. I cant wait to see a vid!
Old 07-18-2007, 12:10 AM
Tom@SpeedInc's Avatar
The Dyno is only rated to 1200hp or so; will find out soon enough.
Old 07-18-2007, 12:16 AM
TT-TECH Veteran
Inspector12's Avatar
Yeah most Drift cars are set up like that with high CR and lots of boost. Just not the best for a street car cause of the fuel.
Old 07-18-2007, 12:19 AM
domination's Avatar
yup, there are a couple of variables that you have to keep under controll. Fuel is a biggie.
Quick Reply: Speed Inc. shop car update
