stock motor need help
Old 08-26-2007, 06:04 PM
Big Bird WS6's Avatar
Default stock motor need help
few quesitons
on a stock ls1 how much boost will it take?
what breaks First?
if you repalce internals, how much boost will it take?
who much horse will it take?
Old 08-26-2007, 06:28 PM
JAvenger007's Avatar
check the sticky threads at the top. They provide info your looking for along with a search. Theres more questions than just those when it comes to FI
Old 08-26-2007, 06:32 PM
lol i know there is i just don't want to do like a stock ls1 block with 14 psi and 750 horses and worry.
Old 08-26-2007, 06:56 PM
2000TurboVert's Avatar
You wont!!
I think the consensus is the LS1 block is good to around 900rwhp..
The internals, anything overr 500 its not IF.. Its WHEN..
I think you could run 500-550's and then once that pops.. WHICH IT WILL!!
I imagine youll melt a piston or pop a ring first... Somepeople toss a rod out of the block... Its all different on every motor....
You can build a motor that will hold as much boost as you can throw at it.. It just depends on what kinda cash you have to drop!
I dont see why with a BUILT 346/7 you couldnt make 800+ rwhp with no problem....
Old 08-26-2007, 08:15 PM
smokinHawk's Avatar
mike brown ran his CE into the nines with a stock bottom end using an incon kit.
he had fuelling and a good tune with good gas.
pistons and bearings are normally the week link.
harlan ran his ls1 or ls6 block with good internalls and a stock crank to an 8.20 i think
how much boost is all relative to the type of heads exhast intake and other componets you have.
most people can get there stock engines to about 550rwhp somewhat reliable
and built bottom ends 700-900 rwhp before the heads start pressing coolant
Old 08-27-2007, 07:00 PM
so if i change the heads and internals. a ls1 block will do just fine for 750 to 850 horse?
Old 08-28-2007, 10:29 AM
RW99's Avatar
...if you spend the money to ensure that (lots of) fuel, spark, and tune are all in line...
And once you're at 800 rwhp, the rest of the driveline is necessary.
Part of the equation is the age of the stock motor in question, if you're just looking to go 450-500 rwhp on a stock bottom.
Old 08-30-2007, 04:51 AM
EPP
EPP's Avatar
Smile
Yes, check this Corvette out. http://www.exoticperformanceplus.com...Car.php?car=40 Bob
