Flipped GTO manifolds on an F-body
Old 11-15-2007, 11:18 PM
2002ws-6's Avatar
Default Flipped GTO manifolds on an F-body
Has any one tried using flipped GTO maniolds where the outlets would face foward above the valve covers. I was thinking with a little machining of the flanges that go against the heads they may fit. I've seen custom headers this way but was looking for a easier solution
I want to leave the cats in the stock location with 2 gt35's and run the downpipes for each turbo where the stock cats are.
Old 11-16-2007, 01:21 AM
b00sted's Avatar
I've never personally seen flipped GTO mani's...But plenty of people flip truck manifolds. As long as those don't have any clearance issues they'd work fine.
Old 11-16-2007, 02:12 AM
DarkJuggalo's Avatar
keep us posted, im curious on clearance. my buddy wants to turb his goat
Old 11-16-2007, 09:02 AM
2002ws-6's Avatar
I know a lot of people flip the truck manifolds, but they point the outlets downward, I'm wanting to see IF I can have them upward.
Old 11-16-2007, 09:32 AM
1INSANEGTO's Avatar
I think they will work... I am going to try and see if I can use them on my GTO and still have A/C and keep everything in the stock location. Us GTO guys have alot more room to play with on the side.
Might want to also talk to ls1turbo about selling there little adapters they have on the GTO's cause there using the stock mainfolds with the adapters.
Old 11-16-2007, 11:44 AM
1CAMWNDR's Avatar
I am thinking that they will be too wide when turned upside down. Probably will hit the inner fender. Of course; solid motor mounts and a BFH could fix that .
Old 11-19-2007, 08:51 PM
1CAMWNDR's Avatar
Did you test fit these yet?
Old 11-19-2007, 10:25 PM
daniel6718's Avatar
post pics of them flipped on the motor
Old 11-20-2007, 06:10 AM
1INSANEGTO's Avatar
I will test fit today and get some pics.
Old 11-20-2007, 02:40 PM
Restricted User
Zero4488's Avatar
Wow...I never even thought of that...
Old 11-21-2007, 09:04 AM
1INSANEGTO's Avatar
I got some pics I will post later. On a GTO its going to be hard becuase the frame rail is close. I should be putting the motor in today. I know there is someone who had a GTO header on the passenger sided and a fliped truck manifold on the driver side and running a single like that.
Quick Reply: Flipped GTO manifolds on an F-body
