Location for WG
Location for WG
In the process of building a custom turbo set up. Doing the merge was a pain in the @ss. I was wondering if i could just cut a hole on 1 of the pipes really close to the merge it would basically be in the merge but only welded on one pipe. THanks
Awesome technical drawing, did you use a cad program or are you just that good?!
What is the turbo setup? Are you going to be running a small turbo with low boost? or a big turbo and big boost?
If wastegate control is important (like, you have a smallish turbo but want to keep boost down on a stockish block) I would put on gate on each side of the merge...see technical drawing 1 or if room is an issue, see tech 2.
Technical drawing 3 would work if you have a large turbo and a large gate (either to control it to low boost, or a high boost setup)
What gate/turbo/motor are you using?
Im running a t4 76mm turbo. 9#s ls1 with stock bottom end, 6.0 heads w/ ls6 cam. The problem is i dont want to cut a hole over where i welded the two pipes togthere. Heres another pro picture of how mine is welded. Will it work how i did it?
http://www.putfile.com/pic.php?img=7205151
Ya i know that is normally the way to place it but i thought it might work also if i mounted it on one pipe but low enough on the merge like this picture.
http://www.putfile.com/pic.php?img=7205418
It seems like it would be low enough to manage both sides.
daily driven street car runs 9.0x has his piping like this
http://www.richmondperformancemuscle.../original.aspx
tti race kit
http://inlinethumb18.webshots.com/31...600x600Q85.jpg
it'll get the job done.
OFI
http://i10.photobucket.com/albums/a1...ure1111002.jpg
im no turbo expert by any means..but looking at kit builders..they all have it like how gordon 1st CAD drawings
tti race kit
OFI
Wastegate placement on high boost cars (Like parish's truck) is not nearly as important as it is on a stock motored car that needs a low boost with good control.
The Tial 44mm is a great gate and can flow enough, even in a bad location, to be ok. I would put wastegate placement at the top of my list of priorities.
Yes, centered in the merge at a 90 will be fine.
