Turbo seems big enough, just making sure!
Old 12-05-2007, 05:39 PM
NHRA Trans Am's Avatar
Default Turbo seems big enough, just making sure!
I found a Garrett T04B with 70A/R compressor, and H trim (70), and "N" trim turbine, with 84A/R. From my research it seems large enough for 400-450 HP, and 5-6 psi, but i wanted your input before i shell out the BIG bucks! Oh this is a real garrett so i dont need a lecture on ebay turbos!
thank you.
Old 12-05-2007, 05:55 PM
LS1TECH Sponsor
DrTurbo's Avatar
thank you.
Baby turbo......will probably choke the motor..lol
Old 12-05-2007, 05:57 PM
Phoenix 5.7's Avatar
thats cam and heads HP numbers. seems if u are wanting that power level, turbo overkill
Old 12-05-2007, 06:06 PM
you can always have room to grow, eventually i'll run more boost, and i am getting a good price so why not!
Old 12-05-2007, 06:20 PM
LS1Tech Sponsor
hellbents10's Avatar
Too small, thats not much off what I have on my winter beater, and thats a stock 2.2l 120hp s-10 with ls6 springs lol. She has seen 24psi in OD at 5000rpms.....I cannot belive the focker has not come apart yet....
Old 12-05-2007, 06:36 PM
bboyferal's Avatar
You're not getting it... That turbo will not have room to grow... In fact, 5 psi may be pushing that little turbo to the limit... If you're okay with the ordeal of turbocharging your car for that limit, then go ahead but don't be deluded into thinking this will have "room to grow."
You didn't need a lecture on ebay turbos but you might need one on compressor maps.
Old 12-05-2007, 06:45 PM
Thanks for clearing things up, but how does this turbo compare to the one that comes with the STS kit, i might be wrong, but the compressor map seems close to the 60-1
Old 12-05-2007, 06:47 PM
SSilverSSurfer's Avatar
even the one on that STS kit blows(not literally either) thats usually why people do upgrade the turbo. if your using a 60-1, it should be accompanied with another of the same resulting in a twins set up like NanyDavidSS
Old 12-05-2007, 07:02 PM
Haha! Twins would be nice, but i am not looking for any more than what the sts offers. Thats sorta my bench mark.
Old 12-05-2007, 07:28 PM
so youre doing an STS set up?
Old 12-05-2007, 07:34 PM
Yeah, i am going to build my own.
Old 12-05-2007, 07:48 PM
build your own front mount :smile:
Old 12-05-2007, 07:59 PM
Isn't there a lot of welding and moveing the radiator and stuff?
Old 12-05-2007, 08:57 PM
theres is alot of welding no doubt that. but if your not scared to sweat a little, do a flipped truck manifold kit. you have to remove the a/c. but you can put a nice sized turbo in there
Old 12-05-2007, 09:07 PM
98turbls1's Avatar
x2... there's about 3 billion write ups on here and also a sticky... read, read, and read some more... You'll have less ground clearance issues with the manifold setup too...
Quick Reply: Turbo seems big enough, just making sure!
