Spark Plug Heat Range
Old 03-10-2008, 03:03 PM
miami993c297's Avatar
Default Spark Plug Heat Range
Does someone know what is the heat range of the AC-Delco 41-800?
What are the closest NGK (TR55 or TR6) of those AC-Delco 41-800?
Christian
Old 03-10-2008, 03:15 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
from nitrous forum
Originally Posted by dlove
Spark Plug Info
**Note: Heat ranges are determined by NGK standards. Not all plug manufacturers follow the same guidelines.
***Note: List is intended for reference only. Please consult with head mfg. and ignition mfg. for proper gap.
****Note: NGK IX and Denso plugs are Iridium.
LT1
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .050
Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Autolite 764; Champion RS14YC6 (stock number 13); Denso IT-16 (stock number 5325)
Nitrous (one step colder)
Heat range: 6
Gap: .035 - .038
Plug: NGK TR6 (stock number 4177); NGK TR6IX (stock number 3689); Autolite 103; Denso IT-20 (stock number 5326)
Nitrous (two steps colder)
Heat Range: 7
Gap: Consult
Plug: NGK BR7EF (stock number 3346); NGK TR7IX (stock number 3690); Autolite AR94; Denso IT22 (stock number 5327)
LT1 w/ AFR heads
Thread – 14mm
Reach – 3/4”
Socket – 5/8 hex
Seat – Gasket
Stock – MFG Recommendations
Heat Range: 9
Gap: Consult ignition mfg.
Plug: NGK 5672A-9 (stock number 7405); Autolite AR3910; Champion C59YC (stock number 792); Denso IQ27 (stock number 5315); Denso IQ01-27 (stock number 5708)(diagonal platinum ground); Denso IQ02-27 (stock number 5711)(horizontal platinum ground)
Heat Range: 10
Plug: NGK 5672A-10 (stock number 7942); Autolite AR50; Denso IQ31 (stock number 5323)
Heat Range: 11
Plug: Denso IQ34 (stock number 5324)
LT1 w/ Trick Flow & Edelbrock Heads
Thread – 14mm
Reach – 3/4”
Socket – 5/8 hex
Seat – Gasket
Stock – MFG Recommendations: approx under 9:1 compression
Heat Range: 4
Plug: NGK FR4 (stock number 5155); NGK BKR5EIX (stock number 6341); Autolite 3926; Champion RC12YC (stock number 71); Denso IK16 (stock number 5303)
MFG Recommendations: approx 10.5:1 compression
Heat Range: 5
Plug: NGK FR5 (stock number 7373); Autolite AR3924 (Racing Plug); Autolite 3924; Champion RC9YC (stock number 2075); Denso K20PR-U (stock number 3145); Denso IK20 (stock number 5304)
MFG Recommendations: approx 11:1 compression
Heat Range: 8
Plug: NGK R5672A-8 (stock number 7173); Autolite AR3911; Champion C63YC (stock number 796); Denso IQ24 (stock number 5314)
MFG Recommendations: approx 12:1 compression
Heat Range: 9
Plug: NGK R5672A-9 (stock number 7405); Autolite AR3910; Champion C61YC (stock number 785); Denso IQ27 (stock number 5315)
MFG Recommendations: approx 13:1 compression
Heat Range: 9 - 10
Plug: NGK R5671A-9 (stock number 5238); Autolite AR3933; Champion C59CX (stock number 296); Denso IK27 (stock number 5312)
MFG Recommendations: approx 14:1 compression
Heat Range: 10
Plug: NGK R5671A-10 (stock number 5820); Autolite AR3932; Champion C57CX (stock number 295); Denso IK-31 (stock number 5321)
**NOTE: Use chart for static compression and adjust heat range for nitrous use accordingly.
LS1 Stock and AFR
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .060
Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Autolite 764; Denso IT-16 (stock number 5325)
Heat Range: 6
Gap: .035 - .038
Heat Range: 7
Gap: Consult
Nitrous (two and a half steps colder)
Heat Range: 8
Gap: Consult
Plug: NGK R5724-8 (stock number 7317); NGK TR8IX (part number 3691); Denso IT-24 (stock number 5328)
Nitrous (three steps colder)
Heat Range: 9
Gap: Consult
Plug: NGK R5724-9 (stock number 7891); Autolite AR93; Denso IT-27
Nitrous (four steps colder)
Heat Range: 10
Gap: Consult
Plug: NGK R5724-10 (stock number 7993); Autolite AR92
LS1 w/ Edelbrock and Dart Heads
Thread – 14mm
Reach – 3/4”
Socket – 5/8 hex
Seat – Gasket
Heat Range: 4
Heat Range: 5
Heat Range: 8
Heat Range: 9
Heat Range: 9 - 10
Heat Range: 10
4.6 Mustang GT
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .054
Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Motorcraft AWSF-32C (copper); Autolite 764; Denso IT-16 (stock number 5325)
Heat Range: 6
Gap: .035 - .038
Plug: NGK TR6 (stock number 4177); NGK TR6IX (stock number 3689); Motorcraft AWSF-22C (copper); Autolite 103; Denso IT-20 (stock number 5326)
Heat Range: 7
Gap: Consult
Plug: NGK BR7EF (stock number 3346); NGK TR7IX (stock number 3690); Motorcraft AWSFA-12C (copper); Autolite AR94; Denso IT-22 (stock number 5327)
Heat Range: 8
Gap: Consult
Heat Range: 9
Gap: Consult
Heat Range: 10
Gap: Consult
4.6 Mustang Cobra (96-01)
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .054
Heat Range: 6
Gap: .035 - .038
Heat Range: 7
Gap: Consult
Plug: NGK BR7EF (stock number 3346); NGK TR7IX (stock number 3690); Motorcraft AWSFA-12C (copper); Autolite AR94; Denso IT22 (stock number 5327)
Heat Range: 8
Gap: Consult
Heat Range: 9
Gap: Consult
Heat Range: 10
Gap: Consult
4.6 Mustang Cobra (03-04)
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 6
Gap: .049 - .052 (have had better results with tighter gap)
Heat Range: 7
Gap: .035 - .038
Heat Range: 8
Gap: Consult
Plug: NGK R5724-8 (stock number 7317); NGK TR8IX (stock number 3691); Denso IT-24 (stock number 5328)
Old 03-10-2008, 03:37 PM
from nitrous forum
I don't see in your quote anything related to my question
Christian
Old 03-10-2008, 03:45 PM
ddnspider's Avatar
were u not looking for an equivalent plug?that shows all the equavalent plugs via ngk ac delco and autolite
Old 03-10-2008, 03:58 PM
You are quite right ddnspider,
I am looking for the equivalent spark plug to the AC-Delco 41-800, and this one unfortunately not included in the list above.
Christian
Old 03-10-2008, 04:11 PM
BattleShip's Avatar
Default Related question
What would plug would be recommended for an aluminum headed LT1 with 9:1, running 9 psi and Delteq? I have used 103 Autolite on the iron heads, but not sure if they are good for this setup.
Thanks and I didn't mean tp hijack the thread just expand it alittle.
Old 03-10-2008, 04:23 PM
ddnspider's Avatar
i saw the TR6/TR55 so there was the equivalent for that.my mistake
Christian
Old 05-25-2009, 11:44 PM
gold98Z28's Avatar
i know this is REAL old, but i have stumbled across it more than once while doing a search. SO i guess i will answer it so when someone else comes across it, it wont be an open question. i found an autolite plug 3924 to be the same heat range(actually crossed to APP3924 double platinum plug) and the NGK number seems to be BKR5E(P-11,IX-11,or Y-11) so it seems to be a heat range 5 plug from what i can cross it to, and the autolite 3924 seems to be the most comon plug used for this application.
Quick Reply: Spark Plug Heat Range
