Anyone get little rock chips on impellor blades?
Old 03-28-2008, 01:57 PM
My2kz28's Avatar
Default Anyone get little rock chips on impellor blades?
Has anyone ever gotten little rock chips on the turbine blades? I have a few small ones on my F1A and sent some pics to ATI, who said to sand them smooth and it will work just fine. Anyone seen anything like this before? Anyone got any pics of the impellor after sanded smooth?
Old 03-28-2008, 02:00 PM
Drew04GTO's Avatar
How deep are the chips? F1A's use cast or billet compressor wheels? I'd be a bit nervous about sanding on them, can't believe ATI told you to. Any pics of your compressor wheel?
Old 03-28-2008, 02:19 PM
MECHAM's Avatar
ew no...my blades look perfectly brand new
Old 03-28-2008, 02:24 PM
Dumb Ass Vette Moderator
ls1290's Avatar
Personally I would sent the impeller wheel to ATI to have it replace/reapired.
Keith
Old 03-28-2008, 03:44 PM
kp
kp's Avatar
If the nicks werent too bad I'd clean them up, impellers arent cheap.
Got any pics?
Old 03-28-2008, 04:45 PM
stevieturbo's Avatar
Do you run an air filter ?
Old 03-28-2008, 05:53 PM
Awake455's Avatar
All ProCharger impellers are 7075 T-6 billet.
Can't just send in the impeller, you would have to send in the entire head unit.
I would be more curious as to the balance of the impeller than any structural integrity issues...how big are these nicks?
Old 03-29-2008, 08:18 PM
EPP
EPP's Avatar
Little nicks don't seem to appear to hurt anything, post up a pic if you get a chance. Bob
Old 03-30-2008, 05:20 AM
crashly's Avatar
you say turbine blades??
mean impeller .....
unless they are real bad, like can feel with finger nail , should be ok..
any change in mass on the blades can put wheel out of balance... will decrease life on bearings.
ash
Old 03-30-2008, 09:37 PM
My2kz28's Avatar
These are the best pictures I can take...I sent these same photos to Ati and they said it shouldnt be out of balance...they recommended sanding the blades smooth based off of these photos I sent them.
Old 03-30-2008, 09:49 PM
crashly's Avatar
nah,
put it in the rubbish bin
get a new wheel and new aircleaner
would put the unit out of balance
ash
Old 03-30-2008, 10:58 PM
Zombie's Avatar
Shouldn't affect it at all. My T76 has some similar nicks in the wheel for years and when I sent it in for a rebuild they said it's nothing to worry about, way too small.
Old 03-30-2008, 11:05 PM
kp
kp's Avatar
I would just knock the high spots down so a crack doesnt start, seen way worse than that..
Old 03-30-2008, 11:12 PM
My2kz28's Avatar
So can I run it as is, or should I try to take some of the edges off? What should I use to do that? I guess it didnt effect things too much, I did make 623 rwhp on 11 psi with a 355
Old 03-30-2008, 11:19 PM
kp
kp's Avatar
That wont change anything power-wise, unless they are really bent or something gets between the blades and housing and tears it up.
I would take a very fine file or a dremel with a fine cartridge roll and just knock down any real sharp edges. Main thing I would be concerned about is a crack starting.
Old 03-31-2008, 04:52 AM
Blownramair's Avatar
dude,
just send the blower back to procharger and have them re-furbish the blades... i had that done... was $300 or so with shipping... hell those blades look DYNAMITE compared to mine but i dont run a filter... Mine were sooo jacked up, looked like the impeller ate a rock! I actually picked quite a bite of HP after procharger sent it back.
they'll prolly throw in a few brand new seals and check it over (wont hurt).
Jay
Old 03-31-2008, 06:24 AM
skinnies's Avatar
not pretty
Old 03-31-2008, 09:09 AM
WAHUSKER's Avatar
My D-1SC looked worse than that & I smoothed the nicks out & ran it for a while. (search for my post 2 years ago?) The worry is developing cracks at the corners of the nicks or losing enough material to throw the balance off. Yours don't look like they will do either to me.....
Old 03-31-2008, 02:08 PM
70Stang's Avatar
Believe it or not, Procharger told us that this wheel would be OK to run...We are going to try it, but it has to effect it somehow...I mean, look at it!!!
Old 03-31-2008, 02:21 PM
Funkster's Avatar
^ Wow, that is some major carnage. I assume some sort of rock creature was slumbering inside?
Quick Reply: Anyone get little rock chips on impellor blades?
