another "Pick my turbo" thread
Old 04-01-2008, 08:26 PM
CBIII's Avatar
Default another "Pick my turbo" thread
Looking to boost my LQ4.
GTP stage 2 LS1 heads (I imagine these put my cr to 9.7-10:1)
FAST 78mm intake (will go away for either a bigger fast or a weiand/ls6)
TSP 231/237 cam
Lid
K&N air filter
Jantzer ported Throttle body
Comp OE lifters
hardened pushrods
TSP ported ls6 oil pump
MLS head gaskets
ARP rod bolts
ARP Head studs
Textralia Clutch
PT* style kit will be running IC/meth/pump gas.
most likely around 10-14psi.
Thoughts/suggestions?
Old 04-01-2008, 09:34 PM
Shawn @ VA Speed's Avatar
what are your hp goals,and that cam is way wrong,i would probably put on a 76 mm,they make nice hp and spool good
Old 04-01-2008, 09:47 PM
CBIII's Avatar
i knew I forgot somethin..haha. Id like to do as much as I can with what I have. 600 to the wheels would be sufficient for now, but room to grow would be nice.. I imagine a 76 would be the way to go, but alot of this is new to me.
Old 04-04-2008, 10:15 PM
CBIII's Avatar
whats the diff between a TC76 and a TC76GTS?
Old 04-08-2008, 09:01 AM
CBIII's Avatar
and by "way wrong", how much so and would it be "too wrong" for this setup?
Old 04-08-2008, 09:35 AM
geeteego's Avatar
TC76 = Journal bearing
GTS76 = Ceramic ball bearing
GrandmasterCow's Avatar
PM sent
Old 04-08-2008, 09:53 AM
CBIII's Avatar
Thats what I thought, but the 76BB is ball bearing..
Old 04-08-2008, 06:15 PM
LS1TECH Sponsor
DrTurbo's Avatar
A TC76 will spool stupid fast and make gobs of power. Easily get you well into the 9's.
Old 04-08-2008, 06:37 PM
CBIII's Avatar
well said. what does the GTS add?
Old 04-08-2008, 07:05 PM
prochargedchevyi's Avatar
Approximately 500-600rpm quicker spool. It doesn't provide any more horsepower, just quicker spool time.
Old 04-08-2008, 07:18 PM
LS1TECH Sponsor
DrTurbo's Avatar
Don't waste your money on BB. With these big cube motors spool up with a 76mm is not an issue. Also nobody makes a ceramic DUAL Ball bearing system. All DBB's use standard steel bearings, only Turbonetics has the ceramic ball bearing at this point and its angular contact single bearing system.
Old 04-08-2008, 07:40 PM
peter@aps's Avatar
The Turbonectics is realy only half of a ball bearing turbo...............it only has one ball bearing at the cold end of the turbo...................sleeve bearing at the hot end.
Peter
Old 04-09-2008, 11:51 AM
LS1TECH Sponsor
DrTurbo's Avatar
Peter
Correct that is why I mentioned it as a single ball bearing system.
