APS TWIN, Which Gaskets for 317 heads
Would I be better off with the 3 layer gaskets or the 5 layer gaskets?
What are the actual bore sizes of each gasket?
I will be running a completely stock bottom end with 317 heads that have been milled.
I will not be running more than 8 to 10lbs of boost at anytime, until I forge it all.
Thanks for your help guys.
Fil
Fil
LS1Tech Sponsor
You will now need the 6.0l headgaskets, not 5.7, if you didnt already know. Just trying to look out and save you some headaches
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Is there any reason I shouldnt get the 5 layers?
Would they be weaker with boost?
Do any of you know anywhere that has a good deal on either the GM 3 Layer or the Cometic 3 Layer Gaskets?
Thanks,
Fil
Thanks,
Fil
I am really leaning towards the 3 layers to keep some compression, for under 3200 rpm range because that will give me a few more ponies down low, of course running the thicker 5 layer ones with a bit less compression I can just add a few degrees of timing and get the ponies back.
Honestly I was just hoping to get some feedback from ppl who have used both, and bounce ideas off you guys.
Thanks
Filbert
Thanks
Filbert
From what I gather the 3 layer gaskets have proved to be the best so far. The 5 layer are still somewhat new and don't have the time on them yet to make a good opinion. I'm in the same boat as you and just got a set of the 3 layer since I know they're a good gasket.
