overheat with verticle radiator?
Old 04-23-2008, 08:47 PM
4SFEDZ's Avatar
Default overheat with verticle radiator?
im thinkin bout moving my radiator up, has anyone heard of any cooling probs? i would also like to go with pushers, would that be a prob?
Old 04-23-2008, 09:00 PM
Josh@KY-Turbo's Avatar
I did it in my last shop car. Use a good set of fans and a 160* thermostat and you are all set. The car would average 170-180* cruising with the TH400.
Old 04-23-2008, 09:47 PM
4SFEDZ's Avatar
did you have pullers or pushers? will pushers hurt flow while drivin?
Old 04-23-2008, 10:18 PM
Pushers. Never had a problem while driving.
Old 04-23-2008, 10:24 PM
RW99's Avatar
A couple of SPAL pushers will do the job, yah.
Old 04-27-2008, 09:17 PM
4SFEDZ's Avatar
anyone else ever have any problems?
Old 04-27-2008, 10:40 PM
6 Second Club Moderator
LASTLS1's Avatar
Mine runs a little warm on hot days, 200-215. Warmer than I would like. I'm going to put a larger volume rad in the car, mine is pretty small, it should be fine.
I just drove it to Speed Inc's open house down the tollway and it ran 180's but it was only in the 50's.
Old 04-28-2008, 12:09 AM
Are you running a stock 210* thremostat or a 160*? It makes a huge difference.
Quick Reply: overheat with verticle radiator?
