No Boost????
No Boost????
My dad and I just finished putting together twin rear mount turbo setup on his 8.1L 2500HD pickup with allison trans. The turbos are turbonetics t62-1 with a .81 exhaust housing and a 5 pound wastegate spring with front mount intercooler. Well once we finally got all the small pieces together we took it for run and well.. no boost. It does make a pound or two on the shift but then goes away. What could be the problem? Are the turbos the wrong size?
LS1Tech Sponsor
alot of things, start checking connections first off. Second you put the turbos in the wrong spot. They are supposed to be in the engine compartment.....j/k. All joking aside, also check your springs in the gates and make sure they are not a 3psi spring or something silly like that.
LS1Tech Sponsor
Well as far as turbo sizing goes that would be good for about 1000-1100fwhp on that motor in conventional setup. It should make a full 5psi by 3800-4200 even with a rear mount setup on those cubes. I image we are talking stock manifolds and 2.5" pipe to the turbos? Wrapped? That motor should kick those turbos like a mule on steroids really. There has to be a leak or a problem with the gage. Is it pulling good, AFR, ignition advance???
1 Post
Where is the wastegate referenced to? If it's the turbine itself.....your lack of boost is the FMIC. Reference needs to be AFTER the intercooler when running a rear-mount setup.
Also, ....have you checked the little things....like making sure there's not a kink in the boost gauge line?
Good luck.
Good luck.
Good luck.
Good luck.
My dad wants to know how much difference wraping the exhaust would help? Will boost hit sooner and by how much rpm? The truck has headers wondering if going back to stock manifolds will make a noticable difference on the truck like the cars do or should he put smaller exhaust housing? Any input suggestions or experiances would help, Thanks.
1 Post
BTW, from what I've heard going back to stock manifolds makes a big difference (less surface area). Unfortunately my wife threw my stock manifolds/ y-pipe away while I was in Iraq so I can't speak from experience........
