OFI turbo headers
Old 06-05-2008, 10:53 PM
JerikSS's Avatar
Default OFI turbo headers
Do the turbo headers keep all factory options. It looks like the driver side header would hit... Does anyone have pics of these installed, with everything on the car.
Old 06-05-2008, 11:09 PM
Josh@KY-Turbo's Avatar
They keep everything in the factory location.
Old 06-06-2008, 01:34 AM
JerikSS's Avatar
These headers look great, but do you think they are over kill for an 8psi application. They are not cheap, it seems like they will be a great starting point for a custom turbo application.
Old 06-06-2008, 01:35 AM
JerikSS's Avatar
Are there other options, similar to them???
Old 06-06-2008, 12:39 PM
obZidian's Avatar
this is off my build... not the best pics but it shows the OFI headers. This a vert with a spohn k-member, mounted on a lq9.
Old 06-06-2008, 02:45 PM
needadvice's Avatar
3rd picture...what is chrome thing right in front of the power steering pump? Looks like its bolted to your inlet pipe.
Old 06-06-2008, 03:23 PM
smokinHawk's Avatar
blow off valve.
Old 06-06-2008, 04:05 PM
JerikSS's Avatar
How is plug access??
Old 06-06-2008, 05:55 PM
theblur98ss's Avatar
I'm in the middle of my OFI install. The headers should work with all factory stuff. I don't have ABS so I cant' say about it for sure. It's very close to the power steering but clears. If you have ETP heads you'll need to do some clearancing. Plug access is pretty tough. The passenger side isn't bad from under the car except for #6 I had to cut off a spark plug socket to get it to fit in on that one. The rest you'll need to use a wrench on the socket to get them. The driver's side isn't bad but is none accessable once the dp is in place.
Old 06-06-2008, 05:57 PM
needadvice's Avatar
This may sounds nuts but...how hard/long is it to just take off the exhaust manifolds to change the plugs?
Old 06-06-2008, 06:52 PM
Jake@EPP's Avatar
The manifolds are pretty stout from our view, we have a build going on (98transguy), and its using a 85mm snail in front of a 4l80e, should be a beast.
We upgraded to a billet powersteering pulley since its a close fit and also moved the alternator uptop for heat issues with the 4in dp.
All powersteering lines are stainless and sleeved in firesleeve.
Also, all the pipes in the kit were sent out for a nice treatment of jethot 2000 black, i will post more pictures this weekend of the progress.
Old 06-06-2008, 08:33 PM
JerikSS's Avatar
I am extremely interested in this kit, but I have low funds right know. I would just need the hot parts, I got to say I love how it looks. Does the kit require you to move the radiator up a little, and change fans??
Old 06-06-2008, 09:59 PM
Subliminal Hit's Avatar
yes and yes...cablebandit cut his core support and used the stock rad/..not sure about fans.
I only have the T4/3" DP but I've changed my plugs 3-4 times without removing anything with all acc. Its not fun on the driver side with the DP on but not that big of deal. Probly a little tougher with a 3.5-4" DP though.
I use a craftsman 5/8 sparkplug socket with machined wrench flats on the end of it and a box wrench for all 8 plugs. A chopped off spark plug boot off some old wires helps get some of them started and should be in everyones toolbox anyways. I think I do the front 2 on the driver side from the top.
Old 06-07-2008, 05:47 AM
DanZ28's Avatar
Plugs are easy to put in and take out by hand from the bottom, but I can't get my sparkplug socket to fit onto two of them on the passenger side. I'm buying the SLP sparkplug socket since it's shorter and been machined for the plug to go all the way threw it then you just use a wrench on it.
Old 06-07-2008, 10:33 AM
PatrickF's Avatar
Does the wastegate recirculate or is it an atmospheric dump?
Old 06-07-2008, 02:10 PM
JerikSS's Avatar
I think its routed into the down pipe.
Quick Reply: OFI turbo headers
